flathead experts?
Old Mar 5, 2020 | 08:59 PM
fordslut's Avatar
fordslut
flathead experts?
hello! i'm on here because I have a 56 f100 that's on the back burner right now, but I have a question about another project.
I have a 59ab in my 36 coupe and I want to un-screw the dipstick mount on the side of the pan.
will this cause nuts, or a threaded mounting plate to drop into the oil?
there are three bolts that mount the threaded inlet to the side, but I've never seen the inside as I wasn't with the rebuilder when he sealed it up. thanks for any info.
here's a pic I got online of what my fitting looks like.
I don't see any way of adding pics.
Old Mar 5, 2020 | 09:03 PM
fordslut's Avatar
fordslut
Old Mar 6, 2020 | 03:01 PM
Rust Wrangler's Avatar
Rust Wrangler
I'm no expert, but if your mount has screws instead of rivets, I believe that is a kit to mount them and remove them without having to drop the pan. The inner threaded plate is intended to be tack welded or brazed to the pan so it stays in place. If the kit was installed as intended, nothing should drop inside the pan....Good luck!
Old Mar 6, 2020 | 04:35 PM
fordslut's Avatar
fordslut
I guess I could loosen the three screws, but not completely, and see if the whole assembly wiggles. thanks for your reply.
newguy399
May 21, 2018 06:14 PM
1973dieselhighboy
Mar 31, 2011 12:42 AM
Huntfamily53
15
Oct 30, 2010 03:23 AM
Eric VerValin
18
Apr 6, 2008 06:27 AM
