Sponsored by: Real Truck
TPMS Light
Old Mar 3, 2020 | 07:50 AM
RickyD's Avatar
RickyD
TPMS Light
Been driving my 2016 F250 Lariat for over 3 years and have never seen the TPMS light come on. Isn't it supposed to illuminate when the key is turned on? I have had the sensors checked and yesterday the dealer tech hooked up his gizmo and said the sensors and tpms module are working, he could see pressure in all 4 but he didn't have the capability to check the dash light.
Old Mar 3, 2020 | 06:04 PM
dirthawg's Avatar
dirthawg
Yes, you should see all kinds of pretty lights at key on.
Old Mar 3, 2020 | 09:45 PM
Jcoles's Avatar
Jcoles
Make sure the tires are topped up properly check the tire placard in the door jam that is what your sensors are registered for your allowed 5 psi over and 5 psi under before the light comes on
Old Mar 4, 2020 | 07:48 AM
RickyD's Avatar
RickyD
Angry
Dropped a tire pressure way down and no light. Dealer has no listing for that bulb so it may mean a new cluster or live without it. I will need to pull the cluster to see how it is lit or if something fell off or broke. It was apart when newer as I had the harness connector problem early on under warranty. The dealer had a new tech work on it and said the only way to fix it was a new harness. They gutted the entire interior including the complete dashboard. 20000 later it did it again but I took care of it pretty easily, wiggle the connector and unclip it from the e-brake.
Old Mar 4, 2020 | 08:40 AM
dirthawg's Avatar
dirthawg
Hopefully it's something simple like a connector not fully seated. Those instrument clusters are expensive, let us know what you find.
sand1
Sep 2, 2014 09:39 PM
Sycostang67
Mar 25, 2005 07:05 PM
mwh
2004 - 2008 F150
Sep 7, 2004 08:32 PM
