Stictation
Old Mar 2, 2020 | 06:03 PM
green_95's Avatar
green_95
Stictation
I think I have stictation, truck misses and is low on power on cold starts until the teuck warms up. My ficm volts never drop below 48. I am running rotella t6. I've been looking at rev x and arch oil 9100. Question is, how often do you need to use these products? Revx is $65 per 8 oz.. I couldn't afford to use it every oil change.
Old Mar 2, 2020 | 06:19 PM
Motohead911's Avatar
Motohead911
Does sound like a classic case of stiction. While I haven't use RevX I have used Archoil with some success. These additives are really just a bandaid. I had similar issues with my injectors and unfortunately the ultimate fix was a new ser of Ford Remans.
Old Mar 2, 2020 | 06:36 PM
TooManyToys.'s Avatar
TooManyToys.
I used Archoil as a bandaid for maybe 4 oil changes until it would not help anymore. I identified the injector with IDS changed the injector, and it had been fine afterwards.
Old Mar 3, 2020 | 12:14 PM
green_95's Avatar
green_95
How do you diagnose a bad injector? Is it recommended to change out just the bad one or all 8?
Old Mar 3, 2020 | 12:37 PM
Visurveyor's Avatar
Visurveyor
Post # 3. Ids...... That is the best way. If you have Forscan or Torque and one goes totally wonky you will get a contribution/balance code. But to diagnose a weak injector, it would be best to find someone with Ids.
Old Mar 3, 2020 | 12:56 PM
SmackDaddy's Avatar
SmackDaddy
You should do some research, check the 6.0 tech folder at the top of the page. Lots of things to know if you own this engine!
Old Mar 3, 2020 | 01:09 PM
Motohead911
What they said. The IDS clones seem to work with varying degrees of success.
Old Mar 8, 2020 | 04:24 PM
Ranchvet's Avatar
Ranchvet
I keep seeing the bandaid issue being thrown out there. How long does the "bandaid" last? Is it even worth it or is it better to just pony up and replace the injector?
dracond
Apr 25, 2013 10:29 AM
wicat3
Mar 6, 2012 10:05 AM
alstieg
Jun 16, 2009 09:21 PM
Trailblazed
Dec 28, 2007 04:53 PM
Bruker
Garage & Workshop
Jan 18, 2005 07:57 AM
