Backspacing question?
Old Mar 2, 2020 | 04:59 PM
boo-yaa138's Avatar
boo-yaa138
Question Backspacing question?
I'm looking at some rims that are 20x8 in the front with 4.54 backspacing and the rears are 20x9.5 with 5.29 backspacing.
My truck is going to have DJM drop beams in the front with a flip kit in the rear. Tires I was thinking about running are 255/45/20 in the front and 295/40/20 in the rear.
I have read to keep the backspacing around half of the wheel width so I was wondering if I'm going to run into issues with rubbing?
Any help before I decide to buy would be great!
Old Mar 2, 2020 | 06:02 PM
Christmas's Avatar
Christmas
These might help
Old Mar 3, 2020 | 10:14 AM
boo-yaa138's Avatar
boo-yaa138
Thanks Christmas for the videos. I will see if I can measure this weekend. Before I get to that I’d like to hear if anybody has experience with running a rim with more backspacing them half the width. Btw these rims are a +1 mm offset.
Old Mar 3, 2020 | 06:36 PM
Pcmdub's Avatar
Pcmdub
Backspacing at half the width = 0 offset.
The rear drums have about 5.5" of protrusion from the stock inner fenders. However, the 295/40 rear will wider than the rim and so you will be REALLY close. If one side of the truck rolls over something higher than the other side, it will scrub the inner tubs.
The fronts will be "okay" but will reduce your turning radius at 4.5" backspace with a 9" tire. It will scrub at wheel lock just a tiny bit.
Old Mar 3, 2020 | 10:57 PM
boo-yaa138's Avatar
boo-yaa138
Thank you for the response pcmdub. So if I understand your post if I was to run a 245/45 on the front and a 285/40 in the rear(or something similar in size) then I should be ok as far as rubbing. I wasn’t set on those sizes for tires. I’m just going off of what others have done. I’m even open to running 20x8’s front and back if it will work better.
Old Mar 5, 2020 | 02:10 PM
boo-yaa138's Avatar
boo-yaa138
Bump back up before this weekend. I want to see if any body else has experience with this before I can pull the wheels off and measure.
Old Mar 5, 2020 | 06:12 PM
Fleetwood271's Avatar
Fleetwood271
My wheels are 20X8 on front with 255/45 tires, and 20X10 on rear with 295/40. I have DJM beams on the front and DJM shackles on the rear.
My front wheels have 0" offset and 4.50" backspace.
My rear wheels have 6mm offset and 5.75" backspace.
Front wheels went on fine. No rubbing, no issues.
When I installed the rear wheels the tire rubbed the bed.
I had to install 1" spacers to prevent the rubbing.
The rear wheels are now centered in the rear wheel wells. I have almost exactly 1" of clearance on each side of the tire.
Old Mar 5, 2020 | 06:25 PM
boo-yaa138's Avatar
boo-yaa138
Thanks Fleetwood. You are the one I got my tire sizes from. This answers my question and if I don't want to run the spacer then I can just go with 20x8's all the way around and do a slightly smaller tire.
Old Mar 5, 2020 | 07:11 PM
Pcmdub's Avatar
Pcmdub
I think this is where you get into trouble. The factors of size, width, and offset/backspace are independent variables. So you can have an 11" rim on the rear that fits if you put a tire on it that is less than 12" wide ONLY if you get the backspacing at 4.75". The key element is that the TIRE does not protrude more than 5" inward toward the bed/wheel tub when measured from the face of the drum (wheel mounting surface of a stock drum).
So if you got 20x8" rims, then the normal backspace is 4.5" and a 245 tire will fit. Here is the chart for you
https://cdn.discounttire.com/sys-mas...sion-chart.jpg
However, you will have 2 inches between the OUTSIDE edge of the tire and the fender. This may not be the look you want. So then people get into spacers....YIKES. Many spacers are now built to high standards, but there are several that have questionable engineering. So you are ALWAYS better off getting wheels that just fit right from the start...
If you want 20x10, then you just need wheels with 4.75 backspace or less and a tire that is not much wider than the rim.
Hope that helps...
Old Mar 6, 2020 | 12:20 PM
boo-yaa138's Avatar
boo-yaa138
Pcmdub I total understand what you are saying and if I could find rims that I liked at an affordable price in the right back spacing then I would buy them.
5 x 5.5 rims that aren't custom made that meet that back spacing are hard to come by. Like I asked above if I was to run a tire like a 285/40 on the rear with the 9.5 rim with the backspacing of 5.29 then I should have more room and it shouldn't rub, right?
Old Mar 6, 2020 | 09:25 PM
Pcmdub's Avatar
Pcmdub
It will be close... 5.29" and my truck has 5.5" maximum space to the inner tub indentation. So it SHOULD fit, but it will scrub from time to time when the rear axle goes over uneven pavement.
Old Mar 7, 2020 | 06:55 PM
boo-yaa138's Avatar
boo-yaa138
Another idea I had was running 20x8.5 rims on front and back and running 255/45 tires all the way around. Then I could buy a high quality 1 inch spacer for the rear. This would give me the “look” of filling the wheel well and it wouldn’t rub at all. Bonus would be that I can rotate the tires!
jerry_s
Mar 30, 2014 09:53 AM
66SWB
Dec 30, 2006 07:47 PM
