Bump timimg or no?
Old Mar 2, 2020 | 04:22 PM
wrongway01's Avatar
wrongway01
Bump timimg or no?
I've got a 96 F150 with a 351 W and was wondering if the base timing of 10* could be bumped a little for better fuel mileage?
Old Mar 2, 2020 | 05:08 PM
stryder's Avatar
stryder
I had my 351 bumped to 10-11° when i did heavy hauling to bring the torque curve down for better off idle pull. I only put 4-5000 miles on a year so i didnt care about mileage. Now that it's my daily drive as I await my 2020, I put it back to factory 8° and actually gained 1-2 mpg.
If you want mileage, I'd leave it alone and be more gentle on the takeoff. I try to keep rpms under 2500 while shifting thru gears.
Old Mar 2, 2020 | 05:45 PM
Conanski's Avatar
Conanski
Yes you can bump the timing 2-4 degrees(factory setting is 10btdc) and you might see a modest improvement in fuel milage when you're not taking advantage of the added zip.
Old Mar 2, 2020 | 06:30 PM
wrongway01's Avatar
wrongway01
I drive like a grandpa all the time anyway. Since this is my first gas vehicle in 20 years I’ve been doing a little reading up on it. I seen where timing had been discussed a few times and was wondering. I’m pretty sure base timing on my 96 with the spout unplugged is 10*. I’ll bump it to 12 and see what happens. It’s getting a constant 12.5 mpg which from what I’ve read isn’t crazy bad. Thanks for the replies
preppypyro
92
Jan 23, 2008 10:30 PM
91BroncoEB
1978 - 1996 Big Bronco
22
Jun 2, 2007 04:40 PM
jjoel
52
Aug 16, 2005 01:54 PM
PAUL96
Nov 6, 2001 12:09 PM
joe ross
Jan 5, 2000 11:27 AM
