valve adjustment
Old Oct 14, 2003 | 03:32 PM
mdh627's Avatar
mdh627
valve adjustment
I just installed a new cam in my 351,put new heads etc. I just got it running and it sounds great. My question is will there be a great loss of power if I didnt get the valves right. Heres how I adjusted them, I first adjusted each valve so ther was no valve lash before I started it. After I got it running I backed each valve off until it started clacking then I tightened it till it stopped clacking, then I went a 1/2 turn tighter. I know if you tighten them too tight it will burn a valve. The small block fords you used to tighten a full turn after they stop clacking. Should I go a full turn or leave it alone. Its running great but Im also curious if it would have more power if the valves were opening a little more. I would appreciate any help
Old Oct 14, 2003 | 04:41 PM
MatthewP's Avatar
MatthewP
It might help if you provided some more details:
- Are you using hydraulic lifters, roller or flat?
- What rocker arms are you using. It appears they are adjustable which is non-stock.
-Matthew
Old Oct 14, 2003 | 07:24 PM
fordzman's Avatar
fordzman
the older motors had adjustable rockers cause i have a set of 69 heads that i'm not running and they are adjustable. i think you turn them down till they stop making noise then tighten them up....
Old Oct 14, 2003 | 08:52 PM
DW2455's Avatar
DW2455
I didn't know any of 351w were ever adjustable unless they were converted. DW
Old Oct 15, 2003 | 05:02 AM
mdh627's Avatar
mdh627
Im sorry I didnt tell you the specifics. Its a hydraulic cam and lifters. Yes the rockers are not original. The rockers that were on it were non adjustable. I had the screw in studs and the old style rockers so I could adjust them. I just want to know if its alright to run it where I have them adjusted. I dont want to rob myself of power. I also dont want to burn a valve. I just want to know how far to tighten the rocker after it stops clacking. I tightened it 1/2 turn more after it stopped clacking
Old Oct 15, 2003 | 05:56 AM
macguyver's Avatar
macguyver
I like 3/8 to 1/2 turn on my own stuff. As long as I'm the one running it, I'll know if one is a little loose and I can tinker. But that's just me. I also like to run solids. (Lots of tinker time.) On a customer's vehicle that might not see much "play time", I'll go 1/2 to 3/4 turn. On yours, 1/2 turn will be fine (as long as the lock nuts hold).
Old Oct 15, 2003 | 07:16 AM
mdh627's Avatar
mdh627
Thanks Macguyver,I appreciate it. I know on the old small blocks I always went 3/4 to 1 full turn. On my own I like a half turn,but like I say I went 1/4 turn and it sounded good and runs great. I was just concerned if I might be losing any power
Old Oct 15, 2003 | 09:48 AM
DW2455's Avatar
DW2455
yup 1/2 turn will be fine. DW
Old Oct 16, 2003 | 05:38 AM
macguyver's Avatar
macguyver
To make a hydraulic cam lose power because of the adjustment, you'd have to adjust the rockers so tight that the valve couldn't close or so loose that it couldn't open all the way. Anywhere else in the range of travel, the lifter just takes up the slack and keeps everything in the same relationship. It's not very critical.
One benefit of a "deeper" adjustment (closer to 1 full turn past clatter) is when the valves float when over-revved, the lifters will pump up, holding the valves open acting like a rev limiter.Depends on how tight you want to rev the engine.
NWVintage
Oct 24, 2012 09:18 AM
texag03
2004 - 2008 F150
15
Jan 25, 2006 08:13 AM
JLinder2
Dec 13, 2005 02:39 PM
packrat56
15
Jun 20, 2004 02:59 AM
cseay1
May 23, 2003 08:05 AM
