Trouble starting when warm
Old Oct 15, 2003 | 07:39 PM
Joe fix it's Avatar
Joe fix it
My dad thinks that it needs a ring job, but I just wanted to see what you guys think. When the motor is cold it will start up no problem, but after I drive it for a while and it is at running temperature, if I turn it off, wait a couple of minutes and try starting it, it will just spin, and spin, I tried full choke, I tried no choke, I tried half choke, the only way it will run is if I pump it a hole bunch of times then hold her to the floor. What do you guys all think???
Old Oct 15, 2003 | 07:43 PM
jwtaylor's Avatar
jwtaylor
Depends do you happen to have an edelbrock intake and carb on it?
Old Oct 15, 2003 | 08:53 PM
Joe fix it's Avatar
Joe fix it
No, actually I got the stock 2brl manifold and motorcraft carb.
Old Oct 16, 2003 | 05:43 AM
macguyver's Avatar
macguyver
It could be heat soak/fuel percolation. Boiling the gas out of the carb when it's shut down hot.
A compression test would verify if the rings were weak.
abe
Oct 6, 2014 11:40 AM
towmater
Jul 27, 2007 12:08 PM
brentleedragon
20
Mar 14, 2007 09:59 PM
boomer202
Jan 11, 2004 09:41 PM
84-250
Mar 2, 2003 11:19 AM
