Carb ids?
Old Oct 14, 2003 | 03:15 PM
OldBlue67's Avatar
OldBlue67
Carb ids?
Ok, I've got a 7TAH and a 9U according to the OEM # on the sides. What does that mean? I was looking through my manuel with the adjustment specs, but I they don't appear to go by those numbers. Thats where the ID thing told me to look and I can't find any numbers besides those. Any ideas?
Old Oct 14, 2003 | 06:42 PM
fordeverpower's Avatar
fordeverpower
2 or 4 barrel?
Old Oct 15, 2003 | 10:30 AM
OldBlue67's Avatar
OldBlue67
they're both 2 barrel.
Old Oct 15, 2003 | 11:49 AM
Mike W's Avatar
Mike W
If you get the float level pretty close, you will be ok. These carbs are pretty much foolproof. Set the idle adjustment screws for the best vacuum.
Old Oct 15, 2003 | 10:12 PM
fordeverpower
i'm not sure want you want to find out but if its identification there are 3 numbers on the right side of the carb. It might like 123 and if you go into carb section on forums they have cfm listings. If you want to adjust them then its pretty self explanetory.
Old Oct 17, 2003 | 06:42 PM
mk's Avatar
mk
I think the number you have is actually 'C7TA H' (C=60's, 7= year, T=truck line), if you took it from the front left side of the mounting flange. That number should show up somewhere for specs. What were these carbs mounted on? The venturii diameter is on the left side of the float bowl in that circle. These carbs all look the same but there are probably half a dozen venturii sizes that flow different cubic feet per minute (cfm).
mike
bhalemail
18
Feb 11, 2019 06:43 PM
dads1977
Aug 31, 2016 01:16 PM
ras4434
May 2, 2006 12:32 AM
Stretch Jr.12
Offroad & 4x4
20
Aug 3, 2005 08:08 PM
woody00
Mar 28, 2005 01:09 PM
