Sponsored by: Innova
battery compatibility...
Old Oct 14, 2003 | 02:54 PM
HandOfGod's Avatar
HandOfGod
I've got an Optima Red Top, only a couple weeks old, and I was considering doubling up with another battery to double the power capacity. But the real question, is, if i double up, with my old battery, which is plenty good, only like, 1-2 years old, would that battery be compatible with the Red Top or would it drain off of the red top when sitting, and cause problems?
Old Oct 14, 2003 | 07:09 PM
DirtyRican987's Avatar
DirtyRican987
i have heard that batteries should be the same age and type but as for reasons y i do not kno im sure someone will fill u in
Old Oct 14, 2003 | 07:27 PM
dbc's Avatar
dbc
You need to use a battery isolator like the ones in RVs. The batteries will "fight" each other to charge or stay charged. Batteries should only be in parallel for short periods of time.
Old Oct 14, 2003 | 07:58 PM
HandOfGod's Avatar
HandOfGod
hmmm i hope that helps me some, i'm not familiar with RV systems very well, ahaha but i'll look into it? is it similar to what they use in boats? because, there i have some experience
Old Oct 14, 2003 | 08:09 PM
dbc's Avatar
dbc
Yes. It is basicaly a set of diodes in a heatsink to prevent the batteries from discharging, but allows the alt to charge both. Some have a field connection, some don't. It depends on the application.
Old Oct 14, 2003 | 10:07 PM
_GEEZER_'s Avatar
_GEEZER_
I would advise replacing the older of the two with a newer battery when doubling up. For ~$120, it's better to be safe than sorry.
Old Oct 15, 2003 | 12:00 AM
HandOfGod's Avatar
HandOfGod
the red top is brand new.... the older battery, a 75 month Die Hard, is only maybe 15 months old... not to be picky, but that aint all that old, should it matter that much? especially if i get an isolator?
Old Oct 15, 2003 | 08:56 AM
PrPlayboy's Avatar
PrPlayboy
When isolated it wont matter. A battery stores power. Are you looking to hook up your system to the red top?
Old Oct 16, 2003 | 11:48 PM
mzimmers's Avatar
mzimmers
You want to look at:
http://www.surepower.com/
Their stuff is excellent in quality and their customer service is quite good.
The only snag I see you getting into is (and I'm assuming this, since you're posting in this section)...neither the Red-top nor the DieHard is a deep-cycle battery. If you're hoping to add a second battery so you can drain it while using the sound system, your "second" battery should be a deep cycle, like an Optima Yellow-Top or a DieHard Deep Cycle model. Otherwise, you're just going to wear out that second battery very prematurely.
Old Oct 20, 2003 | 12:11 AM
HandOfGod's Avatar
HandOfGod
i'm not looking to drain the other battery while i have the other hooked up to the starter/alternator. I am only looking to increase storage capacity, thereby increasing playing time before my battery runs dead... i will check out your site however, thanks
speersy
Jul 14, 2014 07:04 AM
makomarine
Feb 9, 2008 12:43 PM
John311t
16
Sep 26, 2006 10:55 AM
tmuelle
Dec 14, 2005 05:36 PM
Jrock909
Electrical Systems/Wiring
Sep 25, 2003 11:54 PM
