Have you experienced this?
Old Mar 1, 2020 | 06:45 AM
FinnishStroker's Avatar
FinnishStroker
Soot within 10 meters
Was plugged in like 3 hours,decided to start with no glowplugs(i have manual GPs).
Starter spinning maybe 5 secs nothing,then power to glow plugs maybe 5 secs and BAM!
205cc/80% injectors.
I have experienced small puffs with stock injectors in this van but never anything like this,in any vehicle.
Old Mar 1, 2020 | 07:07 AM
01__Excursion's Avatar
01__Excursion
Does the soot look like small solid flakes, or confetti?
I get this on my stock 7.3 on colder start ups, say in the 40's (F) or lower.
While letting it idle sometimes it will blow that confetti soot, not always, but in the colder temps. Seems to be either once the turbo starts spinning, and or the EBV opens.
Nothing like that, I'd say like a handful of confetti is all I get. In addition I never have un-burned soot while normal or hard driving too.
Old Mar 1, 2020 | 07:14 AM
SkySkiJason's Avatar
SkySkiJason
That’s DIRTY!!
We need to figure out why it’s not running good at idle. Looks like maybe too much fuel? Or poor atomization??
Old Mar 1, 2020 | 07:45 AM
pirate4x4_camo's Avatar
pirate4x4_camo
reminds me of the busses in mexico city 20 years ago, god forbid you got behind one, they would literally cover you in nasty layer of black soot.
Old Mar 1, 2020 | 08:18 AM
Walleye Hunter's Avatar
Walleye Hunter
I figured out where I've seen that before...years ago cars and trucks used to have chokes on them and when you first started them up in the winter and there was snow on the ground that would happen. Does it improve or stop altogether if you exercise your glow plugs well before startup?
Old Mar 1, 2020 | 08:36 AM
bigb56's Avatar
bigb56
Every once in a while mine will shoot out some moisture laden soot when starting, I think it is just moisture laden soot that collects in the exhaust then gets blown out.
Old Mar 1, 2020 | 09:25 AM
kbeefy's Avatar
kbeefy
Always use your glow plugs on a cold start. I would let them cook for at least a minute before cranking if below freezing.
Old Mar 1, 2020 | 12:20 PM
FinnishStroker
To be more precise,i wasnt starting while hitting the GPs.
GPs burned the fuel in cylinder that had open exhaust valve,and shooted like shotgun from exhaust.
It was all types of soot,my EBPV is deleted.
Works perfectly normal when activating GPs before start.
Well,just wanted to try it with no GPs,it was plugged in for three hours,in not so cold temp..
I consider myself as an experienced "cold starter",been hassling over 20 years with vehicles,heavy machinery,etc..
It was a mistake to hit GPs,right after starting..
My main consern is that do i have a pissing injector/nozzle...
Is it possible that 80% nozzle can normally inject that much fuel in 5 seconds or so..?
Old Mar 1, 2020 | 12:34 PM
kbeefy's Avatar
kbeefy
The glow plugs stay on after start, activating them after starting is not bad.
The glow plugs shouldn't get hot enough to light diesel. I don't think they would even ignite gasoline.
Old Mar 1, 2020 | 12:43 PM
z31freakify's Avatar
z31freakify
They glow cherry red when activated so yes, they can light gas even diesel.
Old Mar 1, 2020 | 12:51 PM
FinnishStroker
Yes,i know how GP system works in a 7.3
I have manual GPs,i activate them after start sometimes to smoothen it out.
It shooted that crap while activating GPs,no starting,engine not running.
Old Mar 1, 2020 | 01:16 PM
FinnishStroker
Unfortunately no video from actual event..
Old Mar 1, 2020 | 02:12 PM
Walleye Hunter
Oh, so you hit the afterburners, now it's sinking in. It sounds like the engine was running when you did that? If so that kind of surprises me. Even if it wasn't running that kind of surprises me too. And, yes, GP's get plenty hot enough to light #2 fuel oil, check youtube for videos on them, they get a lot hotter than you would expect. At least some smoker grills use them for their igniters.
If I crank on mine in the cold without waiting for the GP's and it doesn't start then turn the key on they will ignite the fuel and make a pop in there. One day I'm going to get my GoPro out and video it for yas.
Old Mar 1, 2020 | 02:19 PM
z31freakify
Ok now I get what you are saying, Ive had that happen to me on my obs when some of my GP were not working correctly.
From my understanding and from my conclusion, the cylinders that don't ignite the fuel when being cranked, still have atomized fuel lingering in the cylinder bore and if that piston is @TDC the glow plug ignites the atomized fuel without ever being cranked thus the backfire. But my truck never threw anything from the exhaust as yours did.
Old Mar 1, 2020 | 03:28 PM
FinnishStroker
I will add that, the soot in pics and video was result of just ONE backfire event,so you can imagine the scale of it..
