Hi looking for a pto that you engage by cable and that has a pto shaft coming off it for a Clark 455 transmission if anyone has one or knows where to get one for this transmission I would appreciate it
You are going to have to get more specific. Most shift via cable, and all have a shaft. Some go front, back or are reversible. 6 bolt, 8 bolt, adapter etc.
The PTO is not a Ford part and would have been installed by the owner or aftermarket equipment installer.
Here's one at the bottom of the list but it don't tell you much:
It’s 6 bolt shaft needs to go from transmission towards the rear. I have a chealse pto that will work with this transmission but the pump is built on to the pto and I would have to re plump the whole dumb bed to make it work
Definitely rather deal with drive shaft hydraulic lines would cost much more to have them made I’ll try tomorrow to get a model number on the other pto
