6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Problem
Old Feb 29, 2020 | 03:48 PM
Dgthomas67's Avatar
Dgthomas67
Problem
I have a 2008 F450 6.4 4wd. I had the EGR removed and deleted and the DPF and CAT. I have a SCT X4. I am running the Performance tune. I have the Performance, Tow, Street, Extreme and Stock with no problem (Which means only Delete with nothing else.) I did not see any Fuel Mileage changes. I am getting the same (Bad Mileage). Why is this?
Old Mar 1, 2020 | 06:50 AM
speakerfritz's Avatar
speakerfritz
Bad mileage on a 6.4 is 10 mpg or less and usually indicates valve train wear.
if your getting 11 going up hill and 14 going down hill you are fine.
Old Mar 1, 2020 | 07:51 AM
Dgthomas67's Avatar
Dgthomas67
Valve train wear
How hard and expensive is that to fix
Old Mar 1, 2020 | 07:57 AM
Dgthomas67's Avatar
Dgthomas67
Valve train wear
Is there another test for the valve train? This truck runs great no loss of power. Clean oil. No smoke. Instant start.
Old Mar 1, 2020 | 11:47 AM
sxrfun's Avatar
sxrfun
Didn't you just do this delete like 2-3 days ago? How far have you driven since? Are you going by what the lie o meter in the truck says for mileage?
Old Mar 1, 2020 | 11:56 AM
sxrfun's Avatar
sxrfun
Also you have a f450.......what rear end do you have?
Old Mar 1, 2020 | 12:44 PM
Dgthomas67's Avatar
Dgthomas67
Did delete date
I did the 2/28/2020. And like I said it has no noises and sounds great and runs awesome. And i am in the performance tune .
Old Mar 1, 2020 | 12:45 PM
Dgthomas67's Avatar
Dgthomas67
Rear end
Howndo I find out which rear end do I have. I am.new to diesels.
Old Mar 3, 2020 | 08:10 AM
sxrfun's Avatar
sxrfun
It'll say on the door sticker on the drivers side door jamb.......I think you'd most likely be looking at 4.88's or I think 4.30's may have been an option? Either way....engine revs high with those gear ratios and you won't get great mileage no matter what....f250 and f350 came with 3.73 or 3.55 gear ratios and got better mileage.
Old Mar 3, 2020 | 10:48 AM
Dgthomas67's Avatar
Dgthomas67
Here is my tag
I have attached a picture of my tag can u tell me what I have
Old Mar 3, 2020 | 03:46 PM
DieselDenny's Avatar
DieselDenny
4.88 Limited slip
Old Mar 3, 2020 | 04:08 PM
sxrfun's Avatar
sxrfun
Unfortunately you aren't going to get great mileage no matter what ya do with those gears......................
Old Mar 6, 2020 | 05:58 PM
machmedic's Avatar
machmedic
Also I would think running it in performance mode might not be the best for MPG.
Tjhunter-jeepman
6.7L Power Stroke Diesel
15
Jun 4, 2020 01:52 PM
fastang50
Apr 28, 2020 06:00 PM
bunce
Modular V10 (6.8l)
Dec 19, 2011 01:49 AM
dhag911
Sep 6, 2011 06:47 PM
BRay09
Jan 3, 2011 10:56 AM
