Headlights
Old Feb 29, 2020 | 10:11 AM
Kadean1234's Avatar
Kadean1234
Headlights
Have a 96 f150 that has an issue with the headlights. If I turn the headlights on I do not get the buzzer that the lights are on when I turn the truck off and get out. Any ideas or suggestion?
Old Feb 29, 2020 | 10:54 AM
restoman92's Avatar
restoman92
You have a ground issue or defective warning module. Does it work if key is in ignition and door is opened?
torq'ta 5 8's Avatar
torq'ta 5 8
check fuses, or door switch, does buzzer go off for leaving keys in ignition
Old Feb 29, 2020 | 11:06 AM
Kadean1234's Avatar
Kadean1234
Does buzz if i have key in ignition. As soon as I pull key buzzing stop even with lights on.
Old Feb 29, 2020 | 11:29 AM
restoman92's Avatar
restoman92
If buzzer does work, then headlight ground to module is open.
Old Feb 29, 2020 | 05:12 PM
Kadean1234's Avatar
Kadean1234
I guess I will have to live with the issue. I have worked on electrical issues with a 1973 ford E100 never again lol.
Old Feb 29, 2020 | 05:29 PM
restoman92's Avatar
restoman92
A large post-it note works well! Install on horn sounder cover.
Old Mar 3, 2020 | 11:42 AM
evan_nugget's Avatar
evan_nugget
Is this an XL truck with the door buzzer? Someone correct me if I'm wrong but I think the headlight reminder is only a feature of the XLT chime module.
Interesting side note - the two modules are interchangeable and the chime is a pleasant upgrade from the buzzer. Roll to the local pick-a-part and snag one. Fits nice in the pocket too.
three.on.the.tree
21
Apr 21, 2016 06:36 PM
Degreaser
Apr 15, 2013 09:25 PM
Smaug
1997 - 2003 F150
Dec 18, 2003 08:19 AM
reddevilf150
Feb 10, 2003 02:45 PM
