Clutch Transmission issue
Old Feb 29, 2020 | 12:19 AM
mustio1000's Avatar
mustio1000
First posting here. And thanks in advance!! need help figuring this out:
2002 F250 4X4 7.3 Diesel Manual Trans 245K Mi. Driving down the road in 4th and down shifted to 3rd with the increasing incline, when I let out the clutch it revved up
as if I had it in neutral no other unusual sounds, tried all other gears and same thing, Clutch remained disengaged, What?? came to the end of my momentum to a rolling stop.
Had to have it towed home. It will shift into all gears while sitting still without pushing down on the clutch pedalI and engine off. I Admit I have never checked the level of transmission fluid, but I did replace the clutch slave with the pre bled pre filled tubes and reservoir from Napa.
This truck has been more dependable than any girlfriend I've ever had and I'm not giving up on her. It has run on cooking oil and even used crank case oil (put in new fuel filter when I made it back) when that's all I had, but it got me HOME!!. I'm not a mechanic but I have done many simple part replacement. Any suggestions would be very appreciated thank's
Old Feb 29, 2020 | 01:37 AM
Wes444's Avatar
Wes444
Measure your distance to the clutch fork. The early version had trouble breaking. The updated version is reinforced beyond that spot.
some have had trouble with the old versions breaking after changing to new and longer weak hydralics
Old Feb 29, 2020 | 06:36 AM
SkySkiJason's Avatar
SkySkiJason
Unusual for clutch to fail disengaged.
The only thing I can think of is catastrophic friction material failure.
Pull the inspection cover off bellhousing and look for evidence of friction material or some other indication of a problem??
Good luck and keep us posted!
Old Feb 29, 2020 | 11:50 AM
mustio1000's Avatar
mustio1000
Thanks We444
Old Feb 29, 2020 | 11:52 AM
mustio1000's Avatar
mustio1000
Thanks SkiSkijason, I'll do that as soon as it stops raining.
Old Mar 1, 2020 | 06:28 AM
shortblockchevy's Avatar
shortblockchevy
Friction disk or pressure plate. Although the fork may be bent, it only affects the disengaging of the pressure plate.
But I've seen "clutch issues" not be clutch issues.
ejcheli
36
Aug 5, 2020 06:54 AM
bronco6767
Sep 4, 2016 01:02 PM
Stymied
21
Jun 13, 2016 09:23 PM
1468LP
Jun 25, 2012 01:47 PM
aprice
Aug 24, 2005 09:29 PM
