Add a 3rd KEY FOB?
Old Feb 26, 2020 | 03:36 PM
Woody2010's Avatar
Woody2010
Add a 3rd KEY FOB?
Before I spend the money, does anyone know if I can add a 3rd FOB to my 2020 F250? I'd prefer the cheaper old style if possible.
Last edited by Y2KW57; Feb 27, 2020 at 04:56 PM. Reason: Added the word "KEY" in title, as FOB can mean a number of other things, not all of them pleasant.
Old Feb 26, 2020 | 04:41 PM
maypo59's Avatar
maypo59
we added a 3rd on our '17.. don't see any reason to not be able to now.. we got the same style as what came with the truck.
Old Feb 26, 2020 | 04:50 PM
2004SD's Avatar
2004SD
You can buy them on amazon for less than $50 and as long as you have two working fobs you can program them yourself.
Old Feb 26, 2020 | 07:33 PM
GABAR's Avatar
GABAR
Cheaper / old style?
What do you mean?
If you have the two FOB’s that came with your vehicle and if both are working, you can add a third one but it’ll be just like the other two.
Old Feb 26, 2020 | 07:38 PM
NorEasterMA's Avatar
NorEasterMA
This is a very good question that I don't think has been answered yet. In 2017, yes you could add a 3rd (or 4th etc) Fob/key yourself as long as you had 2 working fobs/keys. In 2018, this changed, even though the owners manual didn't. The same procedure no longer worked on the 2018+. Some folks (H20Camper) had success but using different methods, but I don't think any particular method has been totally, universally, confirmed. Curious to see if this has changed again for 2020 or if there are still issues.
Old Feb 26, 2020 | 07:46 PM
Woody2010's Avatar
Woody2010
What do you mean?
By cheaper one I meant like the old style pictured below. I didn't want to get bashed earlier so I didn't give too much info. I want to try taking one apart and adding a timer controlled by a raspberry pi or another type of electronics module that will trigger the lock button every day at a specified time so in case I should forget to lock my truck at night, it will do it. Since they added scheduled remote starts to Ford Pass they could easily add a "Lock Check" feature to the app, but wouldn't have a clue who to suggest that to at Ford. My garage door automatically closes if open based on a schedule so our cars can.
Old Feb 26, 2020 | 08:08 PM
Txwhitetailhunter's Avatar
Txwhitetailhunter
I have a ‘19 with the standard key/fob thing. I had a 3rd key cut and programmed to my truck. Not sure if that helps...
Old Feb 26, 2020 | 08:24 PM
Raptor Rob's Avatar
Raptor Rob
Anyone know of a way to get a new key fob programmed if you only have one of your original key Fobs? I ordered one off of Amazon, but My Son lost one of my key fobs, so now i'm down to one key fob.
Old Feb 26, 2020 | 09:12 PM
Truckie256's Avatar
Truckie256
Used, mine only had 1 fob,. Selling non-ford dealer paid my local dealer to order, cut key and program... $380 if I remember.... I got them to do a 3rd for $120 at same time...
If it wasn't so cheap for me for 2, I would have called the local mobile locksmith guy here...he always has a solution and way cheaper than dealer
Old Feb 27, 2020 | 02:15 AM
RPFB's Avatar
RPFB
The frequency on those old style remotes is 315MHz. The frequency on the new style key/remote is 902MHz. So unless the BCM is set up to use both frequencies, it is unlikely that the old style remote will work on a 2017+ SD.
Old Feb 27, 2020 | 07:53 AM
cpobst's Avatar
cpobst
I just programmed a few keys using Forscan for a friend of mine on 2 of his 2011's. He only had one key for each. The Forscan procedure was straight forward although I cannot verify it will work for newer Super Duty's.
Old Feb 27, 2020 | 04:51 PM
GABAR's Avatar
GABAR
You have two choices.
Your local Ford dealer or a locksmith with the proper equipment to program a new key.
Either way and depending on the dealer or shop, at the very minimum, you’re going to be looking at $100.00 dollars.
If you can get it done for less, awesome.
Remember, you must have to working keys before another one can be programmed.
Old Feb 27, 2020 | 04:55 PM
GABAR's Avatar
GABAR
I remember those Fobs from a few Mustangs I’ve owned and you’re right, they’re tiny compared to the modern Fobs.
No, the older Fobs can’t be used.
Old Feb 27, 2020 | 09:27 PM
BroncoRN's Avatar
BroncoRN
Dumb question, but with truck running and key in ignition can you lock doors with another fob?
Old Feb 28, 2020 | 01:06 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I wish one of these would work:
