73 F100 Electrical Problems
Old Feb 26, 2020 | 12:12 PM
Another73F100Question's Avatar
I believe I have a bad ground to my interior electronics. Does anyone have a picture or instructions about the ground connections? Thanks.
Old Feb 26, 2020 | 05:19 PM
Idaho Highboy's Avatar
Idaho Highboy
Veteran: Navy
Do you have a Haynes manual? I did a quick Internet search and it returned me diagrams. If none of those work, I can scan a couple of pages for you. Most grounds should be easy to identify regardless of a diagram. Want to expand on your hypothesis (i.e. what's not working, what is working, etc.)?
- IH
Old Feb 26, 2020 | 06:19 PM
meangreen92's Avatar
meangreen92
There's a ground behind the gauge cluster, which screws to the steering column brace.
Old Feb 26, 2020 | 07:38 PM
So I've fixed the ground cable the goes from the block to the firewall (it was completely dead) and now all my gauges work... My only problem now is my dimmer switch and all cosponsoring dash lights do not work.
Old Feb 26, 2020 | 10:36 PM
meangreen92
Nice! My starter would run away for the several days my truck was missing the block-to-cab ground.
Is your HVAC controls lighting up, or the lights for the headlight and wiper switches? Factory radio?
Will any of that stuff light up when you turn the dimmer far enough that the dome light comes on?
If it's a fuse, then you probably won't have tail lights - the ones which come on with the headlights. Turn signals and brake light may still work... In that case, aftermarket stereo?
Is your Brake Warning Light illuminating? High Beam Indicator?
Old Feb 27, 2020 | 01:06 PM
All fuses are good. The only lights that work are the hi-beam, blinkers, and brake. All external lights are functional. There is a aftermarket radio installed.
Old Feb 27, 2020 | 07:44 PM
meangreen92
Sometimes, people hook an aftermarket radio's ground to the wire for the light in the radio, and it wreaks havoc with the gauge light circuit. It could fry the printed circuit board on the instrument cluster.
The problem is in the dash somewhere most likely. It could be the headlight switch, or a bad printed circuit board, or hopefully just burned out light bulbs.
But your heater controls should light up, along with the headlight and wiper switch indicator window.
DeepRoots
May 1, 2010 02:23 PM
dieselac
Nov 5, 2009 08:04 PM
RangerTuff05
Sep 21, 2006 07:59 PM
BigShelby
Feb 13, 2003 10:52 PM
