VIN QUESTION
Old Feb 26, 2020 | 11:29 AM
ulmapache's Avatar
ulmapache
VIN QUESTION
Tried to decode vin, not a whole lot of info, and the "officilal Ford site declared my vin invalid...there is no catagory for the 6.9 idi. So, how do I go about finding out more info like axle ratio, (door tag does not translate into a ratio that makes sense...3.54, but engine revs seem way to high at 55mph for that ratio...have 3.54 in school bus I drive, an e350, rund around 2000rpm at 55) trans type (either a t18 or t19 borg warner) fuel tank capacities and other tech info? Thx!!!
Old Feb 26, 2020 | 03:16 PM
FuzzFace2's Avatar
FuzzFace2
Try this site Gary's Garagemahal (the Bullnose bible) - Bullnose Forum at the top documentation
Should come to Specifications - Gary's Garagemahal (the Bullnose bible) everything should be in there but give a look around or even join up.
Some of us are on both, cant get enough truck information
Dave ----
Old Feb 26, 2020 | 03:20 PM
FuzzFace2's Avatar
FuzzFace2
Oh on the VIN if you don't have it entered right it will say that, had the same thing with my 2 1981 trucks.
As for the gear ratio it could have 3.54's but your bus could have an over drive transmission and that will drop the RPM.
Dave ----
Old Feb 26, 2020 | 06:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Post the VIN, all the codes printed on the Certification Label or post a pic of the label. ALL of it will be decoded.
Your "About Me" profile says 1984 F250. It would have either a Dana 60 or Dana 61-1 rear axle.
Old Feb 26, 2020 | 07:35 PM
Franklin2's Avatar
Franklin2
All diesel idi trucks with 4 speeds came originally with t19's. If it's a 4x4 truck, it would have either a 3.54 or a 4.10 gear ratio. It could have more selection if it's 2wd. Post the code on the door sticker.
Old Feb 26, 2020 | 08:37 PM
ulmapache's Avatar
ulmapache
Ok.thx for the replies!! Found Garys site shortly after posting... Door label I think says "73" indicating 3.54s, but the tag is old and hard to read...even in the sun with a big magnifying glass...
Yes, bus has OD...probably what makes the difference...and is a Super Duty E450...2001?
sidelinellc
Large Truck
Aug 7, 2018 01:19 PM
royzell
Jun 7, 2010 09:20 AM
csangster
Feb 7, 2008 08:46 AM
Davetopay
Sep 30, 2006 05:25 PM
seth_85
Jan 23, 2006 03:46 PM
