Modular V10 (6.8l)
V10 cold start chatter
Old Feb 24, 2020 | 09:18 PM
JAck19's Avatar
JAck19
I have a 2000 Ex 6.8 with 268k. No idea about any of the service history, etc. Just bought the truck a few months ago.
Just a couple days ago, I was actually outside/around my truck during a cold start (instead of being inside the house or inside the truck). For the first five minutes (almost exactly five) I get a good bit of chatter, diesel-like, even valvetrain-ish. But by the 5 minute mark, it's all gone and running smooth as a baby's behind.
My oil level is right where it should be, top of the hash marks on the stick. I have a Motorcraft oil filter.
What gives? Is it just the age? I'd figure if it were something detrimental, it wouldn't stop after warm-up, but then i don't know these motors that well.
Give me the 411 boys.
Edit: also, it doesn't chatter immediately. It's not until maybe 30 seconds in.
Old Feb 25, 2020 | 09:43 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
You have to locate the sound with a stethoscope - check the valve covers, and the timing chain cover.
My '01 with only 60K miles on it would clack on cold start - sounded like the chain. It was 19 years old when I sold it last year, but it did it for a few years before that. In the spring/summer/fall I'd put 10W40 Castrol GTX in it, and it would go away. Winter months, 5w30 was enough.
Old Feb 25, 2020 | 10:00 AM
JAck19's Avatar
JAck19
Would the Harbor Freight stethoscope suffice, or should I get something like a Lisle on Amazon?
The dealership just did my change with 5w20. Should I be going a little thicker?
Old Feb 25, 2020 | 10:13 AM
krewat's Avatar
krewat
You can use a long screwdriver or a piece of broom handle, just touch one end to the valve cover, the other to the bony area right in front of your ear. Careful - side-load it as much as possible so the engine shaking doesn't hurt your head
Old May 28, 2020 | 11:10 AM
Forresth's Avatar
Forresth
The low mileage 09 clatters for about 30 seconds when cold started.
Old May 28, 2020 | 11:22 AM
ford390gashog's Avatar
ford390gashog
Its probably the well documented piston slap at cold start. Some engines have it and some don't I don't think its ever been a cause of damage.
Old May 28, 2020 | 12:36 PM
Forresth's Avatar
Forresth
piston slap goes away that quickly?
Old May 28, 2020 | 08:02 PM
ford390gashog
Yes! Once the pistons warm up the sound goes away.
motoboy
Dec 9, 2016 09:02 AM
mark996
Modular V10 (6.8l)
Nov 19, 2010 09:08 PM
theoshin
Modular V10 (6.8l)
13
Feb 16, 2007 01:38 PM
BIGBEAR6
Modular V10 (6.8l)
33
Jan 13, 2004 06:36 PM
jorgy
Modular V10 (6.8l)
Dec 31, 2003 12:56 PM
