2009 5.4 swap help
Old Feb 23, 2020 | 08:25 PM
dragford1's Avatar
dragford1
2009 5.4 swap help
I have a 2009 F150 with a bad 5.4 in it. Does anyone know if I would be able to swap in a 5.4 from a 2007 E350 van? That motor only had 20000 miles before it got rear ended and totaled. I figured I would need to swap intakes and exhaust manifolds at the very least.
Old Feb 25, 2020 | 04:42 PM
Tom's Avatar
Tom
Not easily. Your truck has the 3v variant, while the E-van has the 2v motor. You'd need to swap the heads as well as all the accessories, sensors, and other sundry items. It would also likely need a tune to run correctly due to different parts used on the bottom end resulting in slightly different compression ratio.
You're better off finding another 3v.
Old Feb 25, 2020 | 09:47 PM
Oredigger's Avatar
Oredigger
X2 not sure about 09-11 but older vintage vans often had different engine dimensions and configuration due to different space available under the hood. Heads, intake, where your dipsticks are, etc.
Old Feb 26, 2020 | 12:47 PM
dragford1's Avatar
dragford1
Thanks for the replies guys. I appreciate it. Im kind of old school when it comes to the 4.6/5.4 stuff. All my stuff is old! Are there any vans that shared the 3V motor? My father in law has a few vans laying around in various states of being....
Old Feb 26, 2020 | 01:02 PM
Tom's Avatar
Tom
Unfortunately not. To my knowledge the heads are too large on the 3v engines to fit in the chassis.
bubahyde
1997 - 2003 F150
Jun 5, 2015 05:38 PM
fordboyf150
Modular V8 (4.6L, 5.4L)
Dec 12, 2011 01:10 PM
