bubble test results
Old Feb 23, 2020 | 06:16 PM
bilter's Avatar
bilter
bubble test results
I ran the bubble test today. Drove my truck 20 miles for warm up. Pulled into the garage removed degass bottle cover and installed stopper and tube. I was getting 1 small bubble every 2-3 seconds. Disconnected the turbo VGT wire, bubbles essentially went to zero... I let the truck run for another 4 -5 minutes, no change. Plugged the VGT wire back in, bubble rate again stayed at zero. Correct me if I am wrong here but I am taking these results as an indication that I have no issue with the EGR cooler or head gaskets. The EGR results are supported by the appearance of my EGR valve when I pulled it for cleaning last week (a small amount dry carbon, no goo, no moist carbon)
Old Feb 24, 2020 | 01:31 AM
Hartwig's Avatar
Hartwig
Have you seen this video?
Old Feb 24, 2020 | 06:55 AM
bilter's Avatar
bilter
Originally Posted by Hartwig
yes, thank you, This is where I got the procedure that I followed.
Old Feb 24, 2020 | 11:24 AM
BLADE35's Avatar
BLADE35
To check even further you would look a mechanical gauge and go for ride do a few wot runs
But yours sounds ok
Old Feb 24, 2020 | 12:31 PM
bilter's Avatar
bilter
next on my list of "things to do" is triple pillar gauge set for EGT, fuel pressure and engine coolant pressure.. Most everything else I need to see I can check on my Scan Gauge
Wayne Eady
Jul 5, 2021 06:50 PM
gtmustang00
Jan 3, 2014 10:25 AM
96_4wdr
Aerostar
Feb 22, 2013 11:07 AM
Van Diemen
Oct 7, 2009 09:34 AM
