Have an 08 6.4. Changed fuel filters purged the air, but now it will only run for about three seconds. Bled the air for hours. Same results. The dealer has done the same. Not report of leaks, no codes. Truck is egr delete, dpf delete, CAT delete... 136xxx on clock. Dealer says they can see a tune. I dont know what tune is there. Any info would be great.
Need help!!!!!
Dealer pulled filters and made sure they were installed properly. They cant get anymore air out of the system. Has DPF-R Tune from other owner. Dealer thinks it might be causing it to not run.
A stock flash is going to cause engine lights right? I'm ok with that until I get a better tuner. Just want to make sure I'm not gonna cause other damage.
Got the dealer on the phone. They hadn't pushed the fuel cutoff. Said it wouldnt matter because the lower pump was running. I told them to push it anyway for me. Today they're going to crack the fuel lines on the top of the engine and see if that fixes it. If that dosnt work they dont know what to do. Might need to reflash to stock and buy my own tuner for the egr, dpf delete. Will update when I know more.
