Frame mounted mudflaps?
Old Feb 23, 2020 | 10:32 AM
Xwild's Avatar
Xwild
Anyone using a frame mounted mudflap?
I had duraflaps all the way around, and liked the protection - but I've lost both rears due to backing up to curbs, frozen snowbanks, and such. I think the stiffness causes them to not flex enough, and they push just right on the clips and pop them off. Then they're hanging by basically the one screw through the actual bedside, and it eventually tears that out. Lost of a chunk of the lip on one side. (can't see it if you don't know to look at least).
Thinking a frame mounted set for the rears is the way to go. Let something else take the abuse...
Old Feb 23, 2020 | 03:35 PM
TeddyD's Avatar
TeddyD
Gatorback mudflaps with the brackets are an amazing system. I put them through hell and back out in the northern Canadian oilfields. I will never put any other style on my truck after having these. Normal flaps don’t last a week with what I go through.
Old Feb 23, 2020 | 06:38 PM
DSLTRK60's Avatar
DSLTRK60
I was looking at the Gatorback brackets, but quite expensive.
I am currently designing a bracket using a semi truck hanger mounted to the rear overload bracket. I am not a fan of bolting mudflaps to the body.
Old Feb 24, 2020 | 08:15 AM
4RXLA's Avatar
4RXLA
I had my mudflaps from my 2010 custom welded to clear the rear leaf spring squat and still bolt to the frame on my 2020.
1Digger
Sep 27, 2006 06:37 PM
Muddr Trukkr
Offroad & 4x4
Jun 10, 2004 11:23 AM
69crewcab
13
May 26, 2004 10:49 AM
jniolon
Apr 12, 2002 11:19 AM
