Sponsored by: Auxito
Soft brake pedal
Old Feb 22, 2020 | 12:14 PM
dearborntruck's Avatar
dearborntruck
Soft brake pedal
New master cylinder (bench bled) installed, bled brake lines above and below ABS, bled ABS with scan tool, bled below ABS again. Pedal is firm without having to pump when the truck is off, sinks to floor if pressed slowly when engine on, firm if pressed fast. Tested ABS using testing ports. Seems fine. No ABS light. Thoughts?
Old Feb 22, 2020 | 12:20 PM
alloro's Avatar
alloro
Make sure the caliper slides are clean and smooth and that your wheel bearing hubs are not worn.
Old Feb 22, 2020 | 01:09 PM
Bluegrass 7's Avatar
Bluegrass 7
Slow going down is fluid bypassing the master cylinder bore ports.
Can't keep pressure that way.
Be sure the push rod is adjusted to proper length.
Certain ABS fault can also cause this effect.
The power brake booster has vacuum on at all times with the engine running. A booster leak can also put a pull pressure on the diaphragm to pull it down in the presence of the bypass condition.
I would say it's not air in the system by the way you describe it's action but a fault you have yet to find.
Good luck.
Old Apr 19, 2020 | 05:36 PM
blageurt's Avatar
blageurt
Church......bless Him
Old Jun 17, 2020 | 10:08 AM
dearborntruck
New abs pump fixed it, even though the old ones test port passed
Old Jun 17, 2020 | 10:31 AM
alloro's Avatar
alloro
That's frustrating to have it pass only to find out it was the problem.
gwpitzer
2004 - 2008 F150
Dec 21, 2019 01:23 PM
540milotalon
May 22, 2019 04:37 PM
Dave042
1997 - 2003 F150
Jan 16, 2016 11:04 PM
John Markl
1997 - 2003 F150
May 15, 2014 08:01 PM
bradleyjpyle
Jun 19, 2007 09:33 AM
