EGR Temps
Old Feb 21, 2020 | 10:10 AM
Sh92647's Avatar
Sh92647
EGR Temps
Since I can’t get rid of this system, I had some questions about the temps for the EGR system.
Here’s a screen shot at idle, should both the EGR temps be that low? At start up the back two seniors will be -6 degrees. I don’t have any CEL codes.
Old Feb 21, 2020 | 05:03 PM
Just Strokin's Avatar
Just Strokin
What are you using to display these temperatures? An app on your phone? The egr temp should be higher but not sure there should be two as there is only one EGR temp sensor that I am aware about.
Old Feb 21, 2020 | 05:08 PM
Sh92647's Avatar
Sh92647
I’m using the EZ Lynk 2.0
Old Feb 21, 2020 | 05:23 PM
Just Strokin
Have you tried contacting them to see what PID's they are using and if they are for the 6.7?
Note, #1 and #2 in the photo should be reversed. Maybe there are two EGRT sensors, inlet and outlet. Contact EZ Lynk. I would think the temps should be 500-600 or higher.
