Ok this is a Frankenstein truck.
2019 XL Super Duty With a V-10 that is bi-fuel gasoline and Icom propane system.
4x4
Has a 11 Foot word bed and crane on it. weights 12,900.
1500 miles
Have two issues going on.
1. The cruise works great then at some point when i cancel or turn it off it WILL not let me turn it back on. Like the buttons do not respond. ( happened twice)
2. When pulling a light trailer ( 700 pounds) my worker hit brakes and then tried to press gas again and it says on display " Trailer brake Applied" but the throttle had ZERO response. Luckily he was almost as store and coasted in. Turned off truck and fired right back 5 mins later up worked fine. ( happened one time).
Check engine light is on. My cruise won't work with the check engine light on either. Fix whatever's turned the light on, and your cruise will work again.
so the code is a air fuel mixture ratio code. From running on propane and gasoline.
Issue Comes and goes. Light has been on for several weeks. Until Friday night when a timers disabled that code from coming on again.
The code is air fuel imbalance. The Icom propane system is causing it because it runs on both. It was turned off. But the cruise was working intermittently even when the code was on. And still doesn't explain the " Trailer Brake applied" and loosing all throttle.
