'98 E350 7.3L EOD4 problem
Old Feb 19, 2020 | 06:23 PM
ADG's Avatar
ADG
Many times when I shift into neutral or drive with foot on brake, the engine rpm's rise a bit and it stalls and dies. Sometimes in drive, from a stop and applying throttle it loads up and dies....Thanks in advance, Ahren!
Old Feb 19, 2020 | 08:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are there any codes stored?
The places that read codes free CANNOT read these codes. You could use Forscan, a good independent shop, or a Ford dealer.
Old Feb 20, 2020 | 04:06 PM
ADG's Avatar
ADG
I meant to say reverse and drive....I'm not sure what you mean by "codes". It is "chipped" with 5 different power modes with the hand-held plugin device. It is set to OEM stock setting now.
Old Feb 20, 2020 | 04:07 PM
ADG's Avatar
ADG
...Thanks Mark.
Old Feb 20, 2020 | 04:57 PM
Mark Kovalsky
Codes mean Diagnostic Trouble Codes (DTC) that the PCM stores in it's memory when it detects something is wrong.
Old Feb 20, 2020 | 05:38 PM
ADG's Avatar
ADG
The ABS and brake have been on for the last two weeks, and that is when it started to get worse....I live in Panama now and finding a decent independent shop is tough.
NateDu
Feb 6, 2018 07:53 PM
naiku
Feb 1, 2016 08:59 AM
plumberglen
1997 - 2003 F150
Feb 12, 2015 12:27 PM
bigm555
Nov 17, 2005 10:45 PM
greenroses
2004 - 2008 F150
Jun 30, 2005 07:12 PM
