cooling system issues
Old Feb 19, 2020 | 04:34 PM
gcon's Avatar
gcon
I have a 2005 f350 with 175000 miles owned since new. Recently I have had to add coolant every couple of weeks. Lately every so often the exhaust emits a lot of grayish white smoke. The upper radiator is hot but the bottom hose is quite cold. I live in the northeast and at this time of year the temperature is 35 to 40 degrees during the day and 25 to 30 degrees at night. In order to e assured it will start in the morning I usually plug it in at night. Looking forward to any input. Thanks
Old Feb 20, 2020 | 08:47 AM
Byrd.Dog's Avatar
Byrd.Dog
Most likely source of coolant being introduced into the exhaust is from the EGR cooler. It's common for them to fail internally - coolant can get into the exhaust and exhaust pressurizes the cooling system. Might look into a delete or the bulletproof egr cooler.
Old Feb 20, 2020 | 04:37 PM
gcon's Avatar
gcon
I think that you are right about the egr cooler. The part that I understand is that the upper radiator hose and top of radiator are hot to the touch. The bottom of the radiator and lower are cold. I'm guessing that the radiator could be plugged ? Any input would e appreciated.
Old Feb 20, 2020 | 05:03 PM
Brotherbillstruck's Avatar
Brotherbillstruck
What is your coolant temperature? Do you have a way to monitor temperature? The dash gauge is not very helpful. It may be way too hot by the time the dash gauge shows hot. When my thermostat failed closed I had your same hose symptoms. Hot on top and cool on the bottom. I would start with the thermostat. Take it out and boil it to verify it is working.
You can park your truck nose down over night then remove the EGR valve and check for moisture in the hole. Cooler has failed if it is wet.
I believe a failed egr cooler can cause head gasket failure so you should be on top of it. Good luck.
Old Feb 20, 2020 | 06:52 PM
gcon's Avatar
gcon
I don't have a way to monitor the temp. but I will check the thermostat and egr valve.
Old Feb 20, 2020 | 07:07 PM
Visurveyor's Avatar
Visurveyor
I guess I need to go to work for Forscan Lite. I'd make a killing.
Purchase Forscan Lite for your cell. App store.
Buy an Elm327 Bluetooth for Android, WiFi for apple, Dongle. Your in there with info.
Old Feb 21, 2020 | 12:10 PM
Byrd.Dog's Avatar
Byrd.Dog
Your top radiator hose will ALWAYS be hotter than the bottom, as hot coolant flows from the engine through the upper hose to the radiator, down through the radiator to cool, then out the bottom hose to the water pump inlet. The thermostat is supposed to fail to open. If you suspect the radiator being plugged, I'd try flushing it (disconnecting both hoses first). Wouldn't hurt to backflush the oil cooler and flush the rest of the cooling system as well, since you'll have it apart.
Old Feb 21, 2020 | 02:29 PM
FiveOJester's Avatar
FiveOJester
Since it's 35F outside, I'm not surprised your radiator outlet is cold. The radiator is doing it's job. The fact that the top hose is hot and you aren't overheating means there's a good chance coolant is flowing properly. I wouldn't worry about that for now.
I would worry about your coolant loss. Sounds like a case of a leaking EGR cooler. Can't remember the steps for checking, but look in the tech folder at the top of the forum.
babysilk
Aug 16, 2013 10:19 PM
deanzawistowski
Jan 1, 2008 09:50 PM
akfireball
Nov 12, 2006 08:44 AM
SomePunk
1983 - 2012 Ranger & B-Series
Dec 15, 2005 07:49 PM
DightonFord
1947 and Older Ford Trucks
Mar 27, 2002 12:05 PM
