1986 F150 One Owner
#871
#872
#873
The following users liked this post:
#875
10° at 600 rpm, how's the advance? Seems pinging occurred for you loaded and at higher rpm? Can it be solved by a bit more advance? Your mileage seems pretty good so you are probably close to the sweet spot.
#876
I have also had a little pinging with my 300 six on a few different tank fulls.
I just think they are playing with the blends and why the pinging.
You know there is a winter & summer blend and now that it is getting colder we may still be on summer blend?
Dave ----
#877
The ECU in this '86 EFI model is supposed to detect the pinging and retard timing in response. I have my doubts that it works though. I always get the knock sensor code. My original knock sensor was broken (apart) by my carelessness. All I can say for sure about the replacement sensor is that it screws into the proper hole in the manifold and the plug on the harness fits.
I am going to fill the mostly empty rear tank with mid grade 89 octane from Costco. See if that helps. It should.
#878
If you have pinging you do not want to advance the timing you need to retard it as the spark is happening to soon.
Dave ----
Dave ----
#879
Possibly would ping less higher speed.
Stock AOD, stock 3.55 gears and stock tire size.
#880
Costco gas...Is it like BJ's gas... ? Every time over the years I've filled my tank with BJ's gas, I feel it gives less mpg, then other gas I get from say Gulf, Citgo, Shell...
Has anyone else noticed that kind of thing. The cars seem to run ok, but the mpg seems lower. Could that gas be causing the pinging in these older engines ?
I have noticed the lower mpg in my turbo Subaru's, and even the 18' Outback 3.6R.
#881
ECU controls the advance curve. And you mentioned you lost your ping sensor. Are you able to pull any codes?
#882
I think it has to do with the gas blend and the outside temp is what I am seeing.
All you can do is back out of the throttle and drop a gear to get the RPM up.
Dave ----
#884
#885
Is BJ's Wholesale Club Gas Good Quality? Right off the bat, BJ's gas is not Top Tier. This can be a dealbreaker for some people, especially when one of its main competitors, Costco, is a Top Tier gas retailer.
