Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1986 C700 vin decode
Old Feb 16, 2020 | 11:57 AM
backsix's Avatar
backsix
Hi.
1. Thanks in advance NumberDummy. Its very generous of you to help everyone out with your resources & knowledge
2. curious which engine/transmission/rear end this tag (pic) indicates.
3. I've never had a manual transmission before that wasn't instrumented by a tachometer. I've found an instrument cluster for sale from a 1978 with a tach, any idea if I could swap it to get a tach?
4. What automatic transmissions were offered in 1986 year behind a gas engine?
Many Thanks.
Old Feb 16, 2020 | 12:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by backsix
Hi.
Don't know.
Transmatic (Allison).
28,000 lbs. Gross Vehicle Weight Rating.
1FD = FoMoCo USA - Ford Truck - Incomplete Vehicle.
X = Class 7 - Air Brakes, 26,001-33,000 lbs. GWVR range.
C70 = C700 Tilt Cab (gas).
H = 370 2V or 4V (6.1L).
3 = Check digit, FoMoCo use only.
G = 1986.
V = Kentucky Truck Assembly Plant.
A29263 = 1986 Numerical Sequence of Assembly, the trucks specific serial number.
9A = Wimbledon White.
76 = Denver CO Ford District Sales Office, where the original selling dealer ordered the truck from.
153" Wheelbase.
C70280 = C700 Tilt Cab (gas), 28,000 lbs. GVWR
AA8: AA = Charcoal all Vinyl - Full Width Seat / 8 = 91B Custom Cab.
SN = Spicer model CM4054A 5 Speed Transmission.
JQN:
JQ = Eaton model 17121 Single Speed Rear Axle / 6.57-1 / 19,000 lbs. Rear Axle Capacity.
N = Ford 9,000 lbs. Capacity Front Axle with Power Steering.
Old Feb 16, 2020 | 03:18 PM
85e150's Avatar
85e150
Welcome to FTE! Rather than change the cluster, just add an aftermarket tach. Your engine is governed anyway, and with a 370 and 28000 GVWR, you'll probably be up against the governor most of the time anyway....
Do you own this already? How is it configured?
Old Feb 29, 2020 | 12:40 PM
backsix's Avatar
backsix
Originally Posted by 85e150
Welcome to FTE! Rathat than change the cluster, just add an aftermarket tach. Your engine is governed anyway, and with a 370 and 28000 GVWR, you'll probably be up against the governor most of the time anyway....
Yes, I do own it. It's configured with an older flatbed with a 30,000 pound ramsey pto winch. It's had ittle use, around 20k miles. still has paint on the chassis.
I did end up buying the other cluster before i saw your response. Your advice was good. It was not productive as the earlier 1975 cluster used a mechanical tach so wouldn't make sense use.
What you say about being governed makes allot of sense and explains why it never had a tach.
DrCharles
Electrical Systems/Wiring
18
Sep 6, 2010 06:40 PM
Ed Fewlass
2004 - 2008 F150
Jan 17, 2010 03:24 PM
holland501
Jul 13, 2004 05:23 PM
pcman
Nov 27, 2001 10:52 PM
