Hi
I have a 2011 Ranger 4X4 sport and after an emergency brake shoe coming apart it damage the ABS sencer and exciter ring. ABS light came on and code shows a fault on that wheel. Question:. Can these exciter ring be replace? Thanks this is a great forum.
I see you don't have any replies yet, so I'll see if I can get things started. The short answer is Yes, a ABS tone ring can be replaced, for about $18 & change with a Ford part, probably less if you want to use a salvage yard part.
