So far I have had 2 sets of plugs for my 300. Neither set have come with soft washers for some reason. Both set's have loosened up in the hole. Seems every time I check them I have loose plugs again. Is there some reason why spark plugs are not fitted with the base washer on this engine? Almost every other spark plug I have bought for other engines have had them. Can anybody recommend a plug that will stay tight on the holes? I have a vacuum advance distributor with magnetic pickups, an Accel coil, and will soon be converting it to HEI.
. I personal used y14 f champion had 9 years bad luck autolite motorcraft sturdy on copper now ordered ngk v plus copper as well all my life champion ,,,, I'm 55 not still get checked normal blue 8mm and duraspark brass motor craft rig run optimum one barrel great on gas better then any I've ever had get fixing for none ping and octane mix running awesome hei duraspark 2 are very similar in all areas
