I am rebuilding the differential on my 1950 F-2, I am keeping the original Timken split axle.
All the gearing inside looks great, I am replacing all bearings and installing Chuck's 4.12 drive gear and pinion set.
Does anyone know of a source for the pinion gear and side gear thrust washers? I've looked quite a bit, but haven't found anything. These are the parts I'm looking for.
61-4228 Side Gear Thrust Washer =CARPENTER NOS OBSOLETE PARTS in Concord NC has 12 = 800-476-9653.
61-4194 Thrust Block = No one has any.
61-4230 Pinion Gear Thrust Washer = CARPENTER has 28
You shouldn't need to replace the thrust block. It would only contact the back of the ring gear as the ring gear is forced away from the pinion under extreme load. I would be surprised if it has ever contacted the thrust block.
Mark
