front axle
Old May 25, 2008 | 07:10 PM
perk_man's Avatar
perk_man
front axle
Is a reverse ring and pinon used for the front axle in a 4x4?
Old May 25, 2008 | 08:03 PM
montana_highboy's Avatar
montana_highboy
In a high pinion axle yes.
Old May 25, 2008 | 08:33 PM
perk_man's Avatar
perk_man
How does the ring and pinion in a standard axle work then? Why is it not reversed?
Old May 25, 2008 | 08:43 PM
montana_highboy
On a low pinion housing, the pinion gear turns the ring gear towards the bottom, on a high pinion housing it's the opposite and since the pinion gear turns the ring gear towards the top the gears are cut in reverse, the advantages are that the gears are stronger and it gives the driveshaft more clearance.
