PCV hose setup FE 390
Old Feb 14, 2020 | 11:56 AM
Erick678's Avatar
Erick678
Hi everyone,
Let me first introduce myself. I am Erik, 29 years old, living in the Netherlands and owning a 1971 Ford F250 camper special special with an FE 390 with holley 4160 on it.
https://imgur.com/a/I5yRchn
As a novice, I signed up here to gain more knowledge and to ask a question right away.
Due to hot idle issues I decided to overhaul the carburetor first and I found out that someone connected the PCV valve tube to the hot choke. Result: https://imgur.com/XQDW9jy
This is how it was connected: https://imgur.com/GhzCZaF
I do not have a PCV intake on my carburetor. Question 1: where do I connect the pcv valve tube from the valve cover? Question 2: where can I connect the hot choke tube?
Thanks in advance
Old Feb 14, 2020 | 12:41 PM
ford390gashog's Avatar
ford390gashog
Where is the vacuum hose from your brake booster connected? The 4160 has a vacuum port for the PCV on the side of it. The stock manifold has a vacuum tree in the intake on the rear passenger side. Is that port plugged?
Old Feb 15, 2020 | 07:15 AM
Erick678's Avatar
Erick678
The vacuum hose of the brake booster is connected to the intake manifold: https://imgur.com/9mezEei / https://imgur.com/8SXyirv
I dont have an PCV port on my carb. Or is this tube the PCV connector? https://imgur.com/mlb6Iuv
And i cant find the vacuum tree on the intake. Or do i look over it? https://imgur.com/gm5XjE8/ https://imgur.com/XoEHXMe
Thank you
Old Feb 15, 2020 | 07:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1968/72 F100/350 360/390:
As original with Auto-Lite 2100 series 2V carburetor: Smog valve fits into rubber grommet in right valve cover, smog hose routes from valve to nipple on carb spacer plate.
Old Feb 15, 2020 | 08:08 AM
Coastal68's Avatar
Coastal68
PCV hose from valve cover to carb spacer plate:
Old Feb 15, 2020 | 08:56 AM
Erick678's Avatar
Erick678
What if you dont have an pcv valve inlet on your carb spacer?
Old Feb 15, 2020 | 10:16 AM
KULTULZ's Avatar
KULTULZ
Post
Do you see the VACUUM FITTING(s) marked C9ZZ 9A474-A? You would use that port (MODIFY - REPLACE FITTING(S) as it is directly @ the intake carb plenum and will allow a more even distribution of fumes to all cylinders.
If no port, get back.
Old Feb 15, 2020 | 10:22 AM
KULTULZ's Avatar
KULTULZ
Post
The hose marked ??? is a filtered fresh air supply to cool the 12V ELECTRIC CHOKE ASSY.
Old Feb 15, 2020 | 10:45 AM
Coastal68's Avatar
Coastal68
I've seen OEM FE carb spacers on ebay.
https://www.ebay.com/itm/Carburetor-...MAAOSwYpxeOkAz
Old Feb 15, 2020 | 11:23 AM
Erick678's Avatar
Erick678
Maybe a dump question, i'm a newbie... but, i have an hot choke which is not electric. Fresh air doesn't trigger the choke for opening, right?
Old Feb 15, 2020 | 11:32 AM
KULTULZ's Avatar
KULTULZ
Thumbs up
Not a dumb question, just an oversight on my part. I was just explaing the purpose of the hose as it was marked ?????.
As to the hot air supply to your HOT AIR CHOKE, it is drawn from a choke stove on the right exhaust manifold. A fresh air tube runs from the carb air cleaner mounting base to the choke stove.
Sorry about that ...
EDIT -
Here is a photo of a period FE with choke hot air tubes. Thia will give you an idea of what is needed unless you go electric.
Old Feb 15, 2020 | 01:01 PM
Erick678's Avatar
Erick678
Thank you for the explanation. Its clear for me now
Old Feb 15, 2020 | 01:10 PM
Erick678's Avatar
Erick678
Tomorrow I will search extensively for this port on the intake. So far i cannot find this port on my intake manifold where C9ZZ-9A474-A is located on the image.
Suggestions are welcome
Old Feb 15, 2020 | 02:29 PM
Christmas's Avatar
Christmas
You could drill and tap your spacer for a hose fitting. That would work.
Old Feb 15, 2020 | 02:46 PM
yardbird's Avatar
yardbird
Best is to find a spacer plate with the PCV made into it. You don't have to use the water inlets if you find a plate like the one shown. Some don't have that.
Here is one on Ebay right now...
https://www.ebay.com/itm/ORIGINAL-19...oAAOSwTphdxKUH
