P20EE
Old Feb 14, 2020 | 11:20 AM
Fireman130's Avatar
Fireman130
P20EE
I just bought this truck a few months ago, the engine light came on, stopped at a local auto zone, unfortunately this was on a Sunday night. This code came up and it said to replace the diesel exhaust reductant fluid. I never heard of changing the Def fluid. Does this sound correct or does it need a trip to the dealer????? Thanks
Old Feb 14, 2020 | 11:31 AM
kuztomized's Avatar
kuztomized
I don’t currently own a diesel and never have so someone please correct me if I am wrong ... DEF is a consumable fluid, it needs to be refilled (not changed) every so often, 5k miles or so maybe.
Old Feb 14, 2020 | 11:38 AM
Fireman130's Avatar
Fireman130
It's 3/4 full of Def fluid. I never heard of changing it on any of my trucks, company or personal. But if that's all it's going to take to fix the problem, I would definitely try it.
Old Feb 14, 2020 | 11:44 AM
Ding126's Avatar
Ding126
I heard that DEF fluid can get stale.. may been sitting on shelves for months or longer. I also heard some guys buy their DEF at truck stops. Im gussing at a truck stop it is pumped like fuel??
Old Feb 14, 2020 | 11:47 AM
Fireman130's Avatar
Fireman130
I guess it's possible that it could be old. It's been a while since we had to put any in this truck. It doesn't get used that much this time of year.
Old Feb 14, 2020 | 11:58 AM
J-Wat's Avatar
J-Wat
P20EE is a generic OBD code meaning the PCM is seeing an issue with the NOx reduction system not working as it should so it could be anything from a bad sensor, exhaust leak, bad SCR injector, bad DEF, etc... The fill or replace DEF fluid looks like it is just included in a list of recommended maintenance at 40k miles.
Edit: Did not see it up at the top as well. I guess that is the computers best guess as to where to start. DEF can go bad if left to sit but it would take a good bit. It is mostly water but if that evaporates off it can mess with the concentration. Also someone could have put something in the tank they shouldn't have and it is just now causing problems.
Dgthomas67
Aug 1, 2019 10:05 AM
Flooringit
Nov 4, 2017 10:38 PM
bocomojoe
Dec 1, 2008 01:19 PM
lyle_o
Apr 20, 2001 03:20 PM
