Soft break pedal
Old Feb 14, 2020 | 08:12 AM
mikren's Avatar
mikren
Soft break pedal
Hi fellas...havent been here in a while. Guess the ol girl runnin good. While driving my break pedal goes soft to the floor unless i pump it and she hardens up. Pin hole somewhere?..dont seem to be losing fluid at this time but this also just started. Any ideas would be wonderdul.
Old Feb 14, 2020 | 10:02 AM
gDMJoe's Avatar
gDMJoe
Lightbulb
Rather than playing 20 questions ...
HINT/TIP: Put your -complete- vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
Possible causes ...
  • air in the brake system.
  • booster vacuum leak
  • weak, deteriorating brake hoses
  • wrong brake used to fill
  • sticky calipers
    etc., etc., etc.
Old Feb 14, 2020 | 05:10 PM
rbentnail's Avatar
rbentnail
First thing- how long since a brake fluid replacement? I use speedbleeders Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder. No one was sure of the bleeder size so I ordered 1 front and 1 rear OE from from my dealer then matched them up on the speedbleeder website.
I've had a damaged brake hose before. Trust me, if you had a leak there you'd know it.
Old Feb 14, 2020 | 06:32 PM
pdqford's Avatar
pdqford
Master cylinder bypassing.
Old Feb 15, 2020 | 08:01 AM
rbentnail's Avatar
rbentnail
Certainly a possibility but I always recommend starting with easier things and work up to the mechanic-ing.
Old Feb 15, 2020 | 12:30 PM
mikren's Avatar
mikren
Damn sorry fellas...i thought truck info was in my sig. My bad. 2013 fx4 5.0l. 95k on it Just got in from checking it a bit more.had my wife keep pressure while i looked around...no visible leak. Original brake fluid. Pads and rotars new 18 months ago.
Is there a proper sequence to bleed them ?
Front left to right sort of thing ? Tks again fella
just looked it up...gonna go change/bleed fluid.
Will post results.
Old Feb 15, 2020 | 03:19 PM
mikren's Avatar
mikren
Ok...new dot 3 fluid. Syringed all i could from resevoir. Filled with new and bled system til remainder of old fluid was gone keeping resevoir to level while doing so. Same problem.
I'll sit idle in yard....can press pedal to floor, release wait 3 seconds try it again and to the floor she goes. If i pump it it will harden up and slooowly work its way to the floor.
Any thoughts ?
Old Feb 15, 2020 | 03:23 PM
ford390gashog's Avatar
ford390gashog
Replace master cylinder. These were known to be an issue especially on 2013 trucks. They also like to leak fluid into the booster and ruin which requires both to be replaced.
Old Feb 16, 2020 | 11:18 AM
mikren's Avatar
mikren
Tks gashog....sounds like that's next step. Will order/change and posts results
Old Feb 22, 2020 | 01:32 PM
mikren's Avatar
mikren
Right on fellas...got the new master cylinder installed this morning.....bench bled first and all that good stuff....all fixed. Nice firm pedal again. Thanks for all the input. Much appreciated.
Old Feb 22, 2020 | 07:54 PM
pdqford's Avatar
pdqford
And thank you for reporting back the fix. It is also appreciated.
hello113
May 18, 2019 12:08 AM
Fuzzmom
Jul 19, 2014 04:28 PM
n20
Mar 29, 2010 02:34 PM
CruisnPhantom
Feb 14, 2004 09:04 AM
