300 I6 Headers
Old Feb 12, 2020 | 03:49 PM
cstephens's Avatar
cstephens
300 I6 Headers
Hey folks, wanted to start a(nother) thread on exhaust options.
I know it seems like a lot of guys run the OEM EFI manifolds and the walker Y-pipe. All those parts new would be around $150-180 from what I've seen.
Hedman makes a long-tube in steel that comes with non-high temp temporary paint that runs about $250: https://www.summitracing.com/parts/hed-89300/make/ford
Hedman also makes what appears to be the same header with ceramic coating that runs about $550: https://www.summitracing.com/parts/hed-89306/make/ford
Clifford Performance makes one that is around $460: https://cliffordperformance.net/stor...-truck-headers
I recently came across this header for $272 (on sale, regular shows as $485): https://www.protuninglab.com/hds-fpu...SABEgKBvfD_BwE
Doe anyone have experience with this company and especially this header in particular? It shows to be stainless steel, which I have always heard is better than painted steel and exterior ceramic coated (though probably about the same as a high quality fully ceramic coated header). For $272, it looks like a heckuva deal.
What are y'alls thoughts? I might go ahead and ****** one up for the 1983 F-100 that I am planning to rebuild throughout this year.
Old Feb 12, 2020 | 07:28 PM
FuzzFace2's Avatar
FuzzFace2
What intake & carb will you be running?
Any other work done to the motor like cam, higher compression pistons. etc.?
That will make a difference on what to go with.
Dave ----
Old Feb 12, 2020 | 07:48 PM
john jamieson's Avatar
john jamieson
If you haven't already, try asking down on the inline 6 forum.
Old Feb 12, 2020 | 08:04 PM
Franklin2's Avatar
Franklin2
Be warned all these options including the factory efi manifolds take heat away from the intake. This can make the engine stubborn to run in cold weather.
Old Feb 13, 2020 | 06:05 AM
FuzzFace2's Avatar
FuzzFace2
Unless you buy / make the water plate for the bottom of the intake.
I run the EFI manifolds with the water heat plate and no problem with how it runs.
Dave ----
Old Feb 13, 2020 | 04:06 PM
cstephens's Avatar
cstephens
The current plan is to run a 268 Comp Cam. The 4-barrel Offy intake. Heads and shortblock rebuilt. Stockish compression, maybe a slight bump with milled heads.
And a Holley Sniper 2300 EFI kit. With timing control and a stock, locked out distributor.
Old Feb 13, 2020 | 06:07 PM
jackietreehorn's Avatar
jackietreehorn
Another option would be the heavy-duty "dump truck" manifold. Supposed to flow better.
Old Feb 14, 2020 | 07:33 PM
BigBlue 94's Avatar
BigBlue 94
I run a set of the Clifford headers. 15 years with no leaks or thru-rust. Any set of long tubes will require a custom y-pipe of some sort.
The reason for the efi manifolds being so popular is they can be bolted on by anyone and there is a prefabricated y-pipe available. The efi manifolds flow very well for a factory manifold. They wont scavenge quite like a long tube header, but most 300s dont need that per say. They also dont cause starter access problems and they dont radiate heat like tubular headers.
The factory cam has an equal duration as the comp 268 cam. May I ask why you chose that versus something peppier like the Schneider 135H or 140H, or Erson E270321? The comp 268 can basically be mimicked with 1.73 rockers on the factory cam.
Here's a list of all cams available for the 240/300 inline six block.
https://fordsix.com/viewtopic.php?f=2&t=80699
The Holley sniper 2bbl efi system is a good choice for the 300. I know one 300 running the erson cam I mentioned, the 2bbl Sniper efi, 9:1 compression, and efi manifolds. It's a healthy engine.
rat49f6
Sep 21, 2009 08:15 PM
rmalottwtes30
Jul 5, 2006 05:06 PM
rmalottwtes30
Mar 15, 2006 05:41 AM
kidder31264
Jan 21, 2006 02:12 AM
