EGR delete code
Old Feb 11, 2020 | 03:25 PM
JJD's Avatar
JJD
EGR delete code
I bought a 2006. 6.0. I just had the heads studded and the EGR deleted. I was planning on buying a SCT X4 programmer to delete the check engine light due to the EGR delete. But now I've been informed that the SCT programmer will no longer delete the egr check engine code. Is there anything out there that will work. I know the epa is cracking down on the diesel world. Any help would be great. Thanks
Old Feb 13, 2020 | 11:35 PM
JJD's Avatar
JJD
Since no one responded I'm guessing I'm out of luck finding a programmer or solution to delete the check engine egr light.
Old Feb 26, 2020 | 09:53 PM
phonedoc's Avatar
phonedoc
You'll need to find a real old model sct that has not been updated
Old Feb 27, 2020 | 04:02 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
You actually don't need a programmer, the old ones get rid of the light and that's really it. It's just a soft code from the PCM saying it doesn't see any EGR flow. Honestly, the engine won't miss the EGR flow. The only reason you'd need the light off is for emissions.
Old Feb 27, 2020 | 05:42 PM
Motohead911's Avatar
Motohead911
FYI just turning the light off doesnt help with Emissions if your state does an OBD II test.
ben158
Nov 20, 2014 11:58 AM
Jowen1017
Mar 7, 2013 12:14 PM
dvourthis
Mar 7, 2012 07:45 PM
bigjohnsonzc
General Diesel Discussion
Nov 26, 2007 07:09 PM
KFellers
1997 - 2003 F150
Apr 19, 2005 10:21 AM
