6.2L V8 Discuss the 6.2L V8
6.2l spark plug change
Old Feb 11, 2020 | 08:52 AM
Kamhillbilly's Avatar
Kamhillbilly
I know the sevice manual says to change with engine warm but here is the situation the front end is currently removed grill rads etc .So I have easy access to do all the plugs now with a room temperature engine. Is the reasoning for the warm engine spark plug removal ?
Thanks
Bill
Old Feb 11, 2020 | 09:32 AM
Lamoon78's Avatar
Lamoon78
I would say block gets warmed up and expands help them come out easier. Might be wrong though.
Old Feb 11, 2020 | 10:42 AM
duckduke's Avatar
duckduke
I would say they same...………. but ………….. I'm would bet plenty are changed on an ambient or cool temperature. Especially if you try and do all 16 at once. I did see where someone did one side (8) ………. and ran engine a few minutes and did the other 8.
I've never had a problem removing plugs on any engine except my prior 2006 F150 5.4L (yes the one with the special tool to get all the plugs that break ….. and all the many TSBs that are little help). I read every TSB, went over and above what the TSBs suggested in prep, and still broke 7 of 8. All came out with the Lisle removal tool …… but..... 1 plug required a little creative procedure to help the tool work on it. But it eventually worked. Absolute PITA. But these were special designed plugs/head on the 5.4L that finally changed in early 2007.
I'm at 70,000 and am planning to go ahead and do mine soon. Have had plugs a couple of months ...……. just need some motivation.
(also have the fuel pump in box to replace ...…. not looking forward to either project)
Old Feb 11, 2020 | 10:45 AM
Lamoon78's Avatar
Lamoon78
I've never had a problem removing plugs on any engine except my prior 2006 F150 5.4L (yes the one with the special tool to get all the plugs that break ….. and all the many TSBs that are little help). I read every TSB, went over and above what the TSBs suggested in prep, and still broke 7 of 8. All came out with the Lisle removal tool …… but..... 1 plug required a little creative procedure to help the tool work on it. But it eventually worked. Absolute PITA. But these were special designed plugs/head that finally changed in early 2007.
I never have had a problem either doing them with cool engine. Just the only reason I could think of on why they would say that.
Old Feb 11, 2020 | 02:57 PM
Siberexpress's Avatar
Siberexpress
I did mine at Ambient temp on the left side, no problem at all. I did figure out I will do the left side first when it gets to 150,000 miles though since it is a little tighter on the F150.
Old Feb 13, 2020 | 11:08 AM
Kamhillbilly
Thanks or the replies , well just change them all while the access is easier .
Old Mar 6, 2020 | 11:48 AM
Haggis 6.2's Avatar
Haggis 6.2
How did this work out for you?
Old Mar 7, 2020 | 06:39 AM
Kamhillbilly
the truck is a project in my garage unfortunately ive screwed up my shoulder so I haven't been able to do much hopefully ill have enough movement of my arm back shortly to continue
Old May 13, 2022 | 09:40 AM
DaveNTx's Avatar
DaveNTx
Owner's manual specification page only says "Spark plugs-platinum" for my 2013 F250 XLT, 6.2L.
Does anyone know a good Motorcraft part number for these? Thanx.
Old May 13, 2022 | 09:02 PM
johnnyvol's Avatar
johnnyvol
This is what I put in mine.
Motorcraft SP526
Old May 16, 2022 | 12:47 PM
Tarster's Avatar
Tarster
I just posted in another thread, but my two cents... I wouldn't put motocraft plugs back into my truck.. maybe I got a bad batch.. but I had 2 burn the stems out in 40k miles.
Pull the wheel covers on either side and pull the intake and then you should have no problem changing the plugs, The bottoms are best changed through the wheel wells.
Old May 16, 2022 | 12:53 PM
DaveNTx's Avatar
DaveNTx
Originally Posted by johnnyvol
Thanx. I see Motorcraft numbers SP526 and SP526X - do you know if there is a difference in the plugs or is it just a manufacturing batch number difference?
Old May 17, 2022 | 06:04 AM
FaC's Avatar
FaC
According to Ford they are interchangeable.
Old May 17, 2022 | 09:41 AM
DaveNTx's Avatar
DaveNTx
Thanx for the info !
Old May 18, 2022 | 07:20 AM
Ruster's Avatar
Ruster
4wd Low
I believe the reason they say to warm the engine before changing plugs is to reduce the chance of galling the threads, which is more possible with an extremely hot or cold engine.
Secondly, to prevent galling when installing plugs, and making it easier the next time, you should always use never-sieze. In fact, ALL bolt threads on all bolts you reassemble should get never-sieze. I've been using it all my life on everything...it's worth it's weight in gold. And it DOES NOT throw off torque values. (Engine rebuilding manuals instruct to oil all bolt threads to get more accurate bolt torque. Dry bolts bind and you risk under-tightening)
