6.2L V8 Discuss the 6.2L V8
6.2l spark plug change
Old May 18, 2022 | 11:51 AM
explorerdriver's Avatar
explorerdriver
Originally Posted by Ruster
I believe the reason they say to warm the engine before changing plugs is to reduce the chance of galling the threads, which is more possible with an extremely hot or cold engine.
Secondly, to prevent galling when installing plugs, and making it easier the next time, you should always use never-sieze. In fact, ALL bolt threads on all bolts you reassemble should get never-sieze. I've been using it all my life on everything...it's worth it's weight in gold. And it DOES NOT throw off torque values. (Engine rebuilding manuals instruct to oil all bolt threads to get more accurate bolt torque. Dry bolts bind and you risk under-tightening)
Is it any different from a 2V 4.6L mod motor where they said to do it cold? What are the heads made out of?
Old May 21, 2022 | 04:08 PM
fire240's Avatar
fire240
Just did mine at around 53K on the clock. Truck warmed up a little bit in the drive over to my brothers house so I could use his driveway instead of playing in the traffic in front of my house. Was rather easy for all of them. Best thinig I did was pull both front wheels and the wheel well liners and had alot of space for the lower plugs on both sides. Also a 5/8 swivel magnetic spark plug socket was great.
mattri
2015 - 2020 F150
Dec 30, 2019 05:48 AM
geno87_69
2009 - 2014 F150
Oct 30, 2017 01:27 PM
limakid
Oct 24, 2005 06:32 PM
