Replacing springs.
Old Feb 7, 2020 | 08:59 PM
Chrisrhynes1994f150's Avatar
Chrisrhynes1994f150
Replacing springs.
1994 f150 xlt rwd 5.0 auto ...Replacing springs coils and leafs with oem tomorrow
. Any tips pointers and watch out for... Much appreciated
Old Feb 8, 2020 | 12:26 AM
TexasGuy001's Avatar
TexasGuy001
The front is easy. I believe the lower coil spring retaining nut is 1 1/8". You don't need a spring compressor. Just remove the lower shock mount. You may have to push down slightly on the I beam or hub slightly. The rear may be a different story, if things are rusted up, but is pretty straight forward. I would suggest all 6 new bushings and/or new shackles.
Old Feb 8, 2020 | 06:52 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I have had to cut the spring eye bolts to remove the leaf spring so I would suggest to get new bolts for the leaf springs but I see you are in Florida. You probably wouldn’t have seized bolts living down there.
Old Feb 8, 2020 | 08:29 AM
fuelsmoke1's Avatar
fuelsmoke1
Should be pretty straight forward. Did my front coils last summer, took me about 45 minutes. I'm in SC, no rust, everything came right apart no prob.
Only pointer I'd throw in here, when doing either end of the truck, jack up both sides and use good jack stands and block wheels from rolling.
With the antisway bars, having one wheel up and one down puts pressure on the bar and limits your freedom to move the I-beam to get coils out easy. With both sides hanging it's easier. On rear it's easier as both sides are hanging evenly with no pressure on anything.
Old Mar 7, 2020 | 10:46 PM
Chrisrhynes1994f150
SC?? I bou
I'm from Charlotte nc bought the ole girl in Columbia SC she's spent some miles traveling... Btw the springs went smoothly thanks guys
peenhead
Apr 15, 2025 05:05 AM
coley909
Feb 1, 2018 10:15 AM
CDF302v8
Jan 13, 2009 03:04 PM
I_Thnk_Ford
Feb 28, 2005 05:03 PM
