1978 - 1996 Big Bronco
Does this look normal?
Old Feb 7, 2020 | 12:55 PM
bra$$monkey's Avatar
bra$$monkey
Loaded question - 1979 Bronco. I picked it up a couple weeks ago & while inspecting everything I noticed the front pinion seal was leaking. More disturbing was what was leaking out....
The front cover had the top 1/3 pretty rusty (scale) & the bottom 2/3 was clean. I suspect this was caused by condensation after the truck sat for years & years. It could be from getting submerged - but there doesn't seem to be any other evidence of that on the rest of the underside of the truck.
Popped in a new pinion seal - have cleaned up the gear case & cover. Will reinstall tonight I hope - with fresh oil.
Old Feb 7, 2020 | 08:48 PM
Doosenberry's Avatar
Doosenberry
Normal? I don't think so. I, however, removed the yoke on my 9" rear end third member to replace it and what came out was pretty brown similar to that and smelled horrid. I've had both diffs gone through since then and have no issues.
Old Feb 8, 2020 | 10:03 AM
tcinu2's Avatar
tcinu2
Not Normal. It's not fun to clean that mess up
Old Feb 11, 2020 | 03:55 PM
Encho's Avatar
Encho
The Southernmost Mod
Replace all the axle seals, that's oil-water mixed. Good thing you checked it.
Old Feb 12, 2020 | 10:32 AM
EDC8008's Avatar
EDC8008
Make sure the differential vent is connected and the end is as high as it can be under the body, The vent being bad will let water get in especially if you go through deep water.
markag
2015 - 2020 F150
Jul 30, 2019 03:27 PM
edsly42
1997 - 2003 F150
Mar 27, 2017 01:28 PM
mefast
Aug 22, 2014 06:56 AM
Powerstoke73
Aug 16, 2014 07:54 AM
pcman
Feb 4, 2005 11:07 PM
