Backup Sensor
Old Feb 5, 2020 | 04:54 PM
Colu41's Avatar
Colu41
Backup Sensor
So I've only had my truck a week now and have ran into this a few times already. When backing up, Im randomly getting the constant red warning alarm. Sometimes on both rear taillight corners, but I've looked and there's nothing blocking or interfering with the sensors? Is it something else?
Old Feb 5, 2020 | 05:11 PM
GABAR's Avatar
GABAR
Take a damp to wet rag or towel and wash over the backup sensors in the bumper.
Awhile back, I experienced the same problem as you.
Sometimes dirt or debris will cause your problem.
If that doesn’t work, you should make an appointment with your dealer.
Old Feb 5, 2020 | 05:35 PM
Colu41's Avatar
Colu41
Alright I'll give that a go, thanks.
Old Feb 5, 2020 | 09:01 PM
TJReams's Avatar
TJReams
I have a problem on mine that isn't just a quirk of the system. The ramp from the street in my driveway sticks up about 1 inch. My truck and the car both make the system alarm. So is there any unevenness where yo are backing up?
TJ
Old Feb 6, 2020 | 01:42 AM
Colu41's Avatar
Colu41
TJ
I mean, I'm sure there is a little, bit it doesn't do it all the time. As a matter of fact it did it to me yesterday running some errands, then all of a sudden stopped.
Old Feb 15, 2020 | 03:11 PM
Teufelhund323's Avatar
Teufelhund323
5th Gear
Any chance you have some ice built up on the sensor(s) that are showing red? I've had it happen a few times on my '19. It was below freezing so I cleaned the sensors with a rag and some rubbing alcohol and that did the trick.
Old Feb 15, 2020 | 03:49 PM
Colu41's Avatar
Colu41
Nope. Isn't ice. It happens randomly whenever it feels like. Warm day, Cold day. Wet day, dry day. It's really irritating. All 4 sensors on the rear bumper are as clean as they can be. I went through them with cleaner and a qtip 🤷‍♂️.
I know that once they go off I can temporarily mute it for the time being but it's not permanent. And also doesn't do that get rid of your red,yellow,green warnings?
I'll be hooking up my Forscan tool tmrw to get rid of that awful double honk, is there an option in there to possibly silent the rear sensors, but keep the green,yellow red warnings?
Old Feb 16, 2020 | 03:52 AM
flumpydog's Avatar
flumpydog
I had a similar problem and it ended up being an issue with some corrosion in a connection on the wiring harness connected to those sensors.
Old Feb 16, 2020 | 11:43 AM
Teufelhund323
5th Gear
Good luck with the Forscan tool. Wish I could help but I don't know anything about it.
Old Feb 18, 2020 | 08:37 PM
xr7gt390's Avatar
xr7gt390
My 2012 F150 would do the same thing. I put a new sensor in and the problem went away.
KodiakF250
6.7L Power Stroke Diesel
May 25, 2018 11:33 PM
Mi04f150
2004 - 2008 F150
Jun 28, 2016 10:27 AM
W7PSK
Jan 28, 2016 11:41 AM
tcjhkbjt
Mar 10, 2014 09:55 AM
Skiddz
Sep 13, 2002 05:30 PM
