Adjustable track bar
Old Feb 10, 2020 | 10:56 AM
wicked 2018's Avatar
wicked 2018
lewis built
Old Feb 10, 2020 | 08:34 PM
JoeVH's Avatar
JoeVH
I have the BDS, along with their 2" lift. Theirs is like a turnbuckle, which can be adjusted without removing an end, which I HIGHLY recommend. I've adjusted it several times, as it seems to take a while for this axle to shake out where it wants to be at.
Old Mar 8, 2020 | 10:19 AM
PENOBSCOT's Avatar
PENOBSCOT
In reading the instructions for the BDS track bar it says "It may be necessary to grind the axle gussets for clearance." It also says "A small amount of grinding on the frame crossmember lip may be required for clearance to the trackbar under compression clearance." Did you have to grind anything to make this track bar work?
Old Mar 8, 2020 | 10:54 AM
Absoluteblack2018's Avatar
Absoluteblack2018
Originally Posted by TX Crawler
Only time will tell if the bushing is stronger than stock but it's not the same bushing. As a whole, the bar is about twice as heavy as the stock bar. I wanted to stay away from heim/rod end style joints -- I've got a crawler that squeaks like crazy when its dusty and I didn't want to have to listen to that nonsense all the time.
That's why i was staying away from an adjustable track bar. I've had experience with both low end and "high end" "professional" heim joints and they all end up squeaking and creaking. The only way i was able to stop it on the traction bars on my old truck was to spray them once or twice a week with dry lube, but who the hell wants to crawl under their truck once or twice a week to prevent squeaks.
With just a 2.5" level, should I be fine with just a track bar drop bracket? I'd prefer to keep OEM on the track bar. Currently the previous owner of my truck only added coil spacers and shock extensions, and the track bar is definitely not parallel.
Old Mar 8, 2020 | 11:17 AM
JoeVH's Avatar
JoeVH
I didn't install it myself, I had a shop do it. They didn't say anything about needing to grind any metal, and I haven't seen any indication that they did. Not to say conclusively they didn't, but I don't think they did.
Old Mar 8, 2020 | 11:39 AM
JoeVH's Avatar
JoeVH
Initially I had the 2" BDS kit installed, along with their drop down track bar bracket. That's when I noticed my axle sticking out on the passenger side. I called BDS and asked why they provided a drop down bracket that was supposed to compensate for the lift and keep the axle centered, but hadn't bothered to design it correctly. They told me that they made the bracket to compensate for most of the trucks, but said that these trucks come from the factory with a lot of variance among individual trucks, and so they recommended their adjustable track bar if I wanted to center the axle. After that I took a look at my old 97 F350, which my son now owns but I had owned for 20 years, and noticed the tire sticking out on the driver's side way worse than my 17 was sticking out on the passenger side. My 97 front end is stock, and all of those years I never noticed that, but it must have rolled off the factory floor with a bunch of offset to the driver's side!
Old Mar 8, 2020 | 12:16 PM
SARDiverDan's Avatar
SARDiverDan
Not that it matters; however, I am probably going to go with this one for my truck that has no lift or level kit installed but it does accommodate trucks with up to a 6" lift.
https://us.bddiesel.com/products/for...31243244273733
Old Mar 8, 2020 | 01:35 PM
jollyrogr's Avatar
jollyrogr
it looks decent though it says OEM ball joint - I hope that doesn’t mean Motorcraft
Old Mar 8, 2020 | 02:09 PM
SARDiverDan
It probably does have an OEM joint but they are easy to replace when they wear out. The other option is a heim joint but those also need replacing once they wear out so no matter what you get, you need to be able to replace the components. I am looking for a more robust bar with adjustability. Replacement parts are another factor. While they do have some high-end options with special joints, are these "special" joints still going to be available 10+ years from now when they need to be replaced? One of the issues I am having with my 02 is that Ford no longer makes many of the parts and replacing broken parts with junkyard parts is only a temp fix so I am thinking more everyday about selling the 02. Not because it's not a good truck but because the longer I keep it, the harder it becomes to maintain it in the way I prefer.
Old Jun 9, 2020 | 12:17 PM
paydirt's Avatar
paydirt
Originally Posted by Vezfly
PMF for me as well, along with drag link
Direct replacement or "offroad" version of the drag link?
RGH2019KR
Mar 27, 2019 11:05 AM
GreatWhite99
Nov 25, 2009 08:49 PM
UncleBob75
Oct 13, 2003 12:21 PM
steve83
Jan 14, 2003 06:40 PM
