Sponsored by: Kumho
9” Rotor???
Old Feb 5, 2020 | 11:43 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
9” Rotor???
Not sure where to post this so I’m putting it in both Brakes & Axles.
I’ve got a big bearing Ford Truck (5X5 1/2) 9” that is missing everything Brake related to include the backing plate bolts. While looking for replacement parts it occurred to me that for what I would need to spend purchasing all the drum brake replacement parts I could just as easily purchase Disk brake parts. My concern is I can’t find a kit or post that doesn’t require you to grind, turn, or whatever other means your axle flange down to about 6 1/8”. My flange is 7” and cutting it that far gets pretty close to the wheel studs.
Anybody done this conversion and know a rotor (part number or year and make vehicle) that will clear the axle flange? I would like to use a vented rotor with Cadillac rear calipers.
bjmayberry2
Feb 5, 2020 11:45 AM
smokewagun
2009 - 2014 F150
Aug 15, 2018 07:57 PM
crazedfox
15
May 2, 2009 09:29 PM
surewhynot
19
Aug 23, 2007 04:08 PM
Coneynew
May 23, 2007 12:54 PM
