SYNC questions
Old Feb 4, 2020 | 07:52 PM
johndeerefarmer's Avatar
johndeerefarmer
SYNC questions
So Sync 3 gives you the 10" screen in the center of the truck. With Sync 3 you can use Android Auto correct? Do you still have Sync's navigation system? Its just not voice activated? And they want an extra $500 to turn on voice navigation for Sync?
Making sure I understand the options.
Old Feb 4, 2020 | 07:58 PM
Robbgt's Avatar
Robbgt
Non-nav Sync3 works with Android auto so Google maps, Waze, etc... It's still voice activated (through Google assistant and the buttons on steering wheel) and works great. I'd never pay extra for the factory nav myself.
Keep in mind that Android auto only works when phone is plugged into USB port.
Old Feb 4, 2020 | 08:16 PM
johndeerefarmer
Thanks Ford navigation is not worth $500
Old Feb 4, 2020 | 08:41 PM
Robbgt's Avatar
Robbgt
The thing Ford nav HAD going for it was the ability to work without a cellular data connection. Now you can download map sections to google maps or Waze ahead of time so they will work in areas with no data but can still navigate with stand-alone gps signal.
Upper trims can send the factory navigation to the cluster screen which Android auto can't. EDIT: It was confirmed that Android Auto CAN send this to cluster with Sync 3.4, see post 8
Old Feb 4, 2020 | 08:48 PM
ForCal's Avatar
ForCal
It's an 8" screen.
Old Feb 5, 2020 | 06:40 AM
satz28406's Avatar
satz28406
Maybe I've not used Waze enough through Sync, but I found it to react too slow for me when I've used it.
Old Feb 5, 2020 | 06:46 AM
Robbgt's Avatar
Robbgt
I haven't tried waze so I can't comment. No issues with google maps through android auto here - that is my primary screen 99% of the time unless I forget to plug my phone in or going for a short trip.
Google purchased waze in 2013 and has since integrated the features into google maps. You can see the same information on road hazards, speed traps, etc... The only downside is I haven't found a way to report these through the android auto interface.
Old Feb 5, 2020 | 07:19 AM
tortue71's Avatar
tortue71
Since I upgraded sync to 3.4 , android auto does send directions to the cluster screen
Old Feb 5, 2020 | 07:23 AM
Robbgt's Avatar
Robbgt
Awesome, good to know - even less reason to opt for the Ford navigation.
Old Feb 5, 2020 | 08:05 AM
johndeerefarmer
How large is the Sync 3 screen on an XLT?
Old Feb 5, 2020 | 09:21 AM
Robbgt's Avatar
Robbgt
​​​​​​For all trims the Sync 3 screen is the same size 8"
Old Feb 5, 2020 | 11:53 AM
GABAR's Avatar
GABAR
It’s a 99.9% certainty that screens larger than the current 8 inch will start and appear in the 2021 F150 first and trickle down to the SD’s a year later or maybe in the 2021 SD.
Unfortunately, I’m sure one will have to jump up to a trim package above the XLT to get it.
Old Feb 5, 2020 | 04:14 PM
johndeerefarmer
Can I listen to Tune In Radio or other radio Android apps AND see and use WAZE or Google Maps at the same time?
Thanks
Old Feb 5, 2020 | 04:51 PM
GABAR's Avatar
GABAR
Thanks
I know it’s possible on Apple CarPlay because I do it all the time but I’m not sure about Android Auto.
Old Feb 5, 2020 | 05:06 PM
darrellbarnes's Avatar
darrellbarnes
Thanks
You can listen to Pandora for sure while running Google Maps. Was doing that yesterday. Pandora is listed in the Sync 3/ Android Auto supported apps.
I'm a new fan of Google Maps with Android Auto. I was liking the Ford NAV until I changed my route while on a Ford NAV route. Ford Nav would not "recalculate" and insisted on going back to where I veered off the route even when I got to my destination.
