Sponsored by: Real Truck
Fuse #8 keeps blowing
Old Feb 3, 2020 | 10:49 PM
Jos92's Avatar
Jos92
I’ve narrowed down the problem. Fuse #8 blows out when I connect the cluster light adjustment ****(next to the light switch)Don’t know where to go from here? I have a 2001 F250 7.3
Old Feb 3, 2020 | 10:52 PM
Jos92's Avatar
Jos92
Also tried a different switch and it did the same thing
Old Feb 4, 2020 | 08:39 AM
redford's Avatar
redford
FTE Leadership Emeritus
I would start with inspecting the wiring harness for the dash lights, the switch and the dome/cargo lights. You have a short to ground somewhere that is causing high current draw which in turn pops the fuse.
Old Feb 4, 2020 | 09:43 AM
alloro's Avatar
alloro
Could be that one of the switch bulbs connected to the output of the dimmer switch is internally shorted.
Old Feb 4, 2020 | 03:09 PM
Jos92's Avatar
Jos92
How would you check the switch? Looks normal to me from the outside
Old Feb 4, 2020 | 07:17 PM
Jos92's Avatar
Jos92
I feel stupid it was a dome light that was not installed properly🤦‍♂️ That fixed my issue thanks anyways
charecter1
Jul 19, 2016 05:09 PM
rlporter507
Dec 27, 2010 11:45 AM
Former Jeeper
Mar 23, 2010 01:48 PM
cbeaur
Electrical Systems/Wiring
May 9, 2003 03:54 PM
99EX44
Jan 30, 2002 09:02 PM
