Crown Vic swap
Old Feb 3, 2020 | 12:28 AM
sladedunafin's Avatar
sladedunafin
Crown Vic swap
Hey guys, I have a 1978 f100 flareside. I did a crown Vic swap on the front but I’m not sure what I should do in the rear to get it the same height. I flipped the axle so it’s on top of the springs but it sits a little lower than the front. Any advice would be greatly appreciated. Thanks.
Old Feb 3, 2020 | 11:49 AM
flowney's Avatar
flowney
How much do you want to raise the rear? A taller tire can give you an inch or two and look good too.
Old Mar 1, 2020 | 09:44 PM
Nash1974's Avatar
Nash1974
There is lift kits for crown vics online thanks to people that like the oversize rims. If you don't find what you want there maybe try a tire shop or fabricate your own lift blocks.
Old Mar 1, 2020 | 09:46 PM
Nash1974's Avatar
Nash1974
Could also get lowering springs for the front
Old Mar 1, 2020 | 09:50 PM
Nash1974's Avatar
Nash1974
depending on the year I suppose it would most likely be coil spring spacers to lift the rear up. What year crown vic chassis did you use?
Old Mar 2, 2020 | 08:53 PM
RalphXL's Avatar
RalphXL
Sounds like the OP swapped in the Crown Vic front suspension and is trying to get the original f-100 rear suspension the be level with the front.
Jess
gator1gear
Dec 12, 2009 08:31 PM
encore243
Apr 30, 2009 08:12 AM
