welding on 8.8
Old Feb 2, 2020 | 08:28 PM
BayStYat's Avatar
BayStYat
welding on 8.8
are the axle tubes on an 8.8 mild steel? I want to add a 4 link and want to make sure i can weld on the axle tubes
thanks
Old Feb 3, 2020 | 03:03 PM
Freightrain's Avatar
Freightrain
You can weld on most any axle tube. They are all commonly mild steel.
Are you replacing the ends also? Once you install the 4 link brackets it will be bent, especially if if you only use 1/2 brackets that don't wrap around the tube. You can straighten the tube, but sometimes it's easier to just replace the ends and install them last which will make it straight. That is if you have a jig to do it?
I've welded the tubes to the housing(cast) with mild steel mig. The factory plug weld isn't bad, but if you try to put power through it you might want to weld them solid so it doesn't break the plugs and rotate on you. Since you are putting brackets on and having to straighten it, you might look into it.
Old Feb 3, 2020 | 03:49 PM
BayStYat's Avatar
BayStYat
Freight,
are you saying the tubes will bend when I weld the brackets?
Old Feb 5, 2020 | 09:47 AM
Freightrain
Typically. If you apply heat to one side of a tube like that, it will PULL to that side. It's only about 1/4" wall, so it will move. As it heats, it pushes, then when it cools it will pull farther back, thus creating a bend.
I've straightened axles by welding a "pad"(square spot) on the back side and then quenching with wet rag to get it to pull back. Then just grind the pad off if you don't want to see it. You'll still need something to check straightness. You can use the axle and see how easily they slide into housing, but the 8.8 has roller bearings in the tube and might not be as accurate as a 9" with large sealed bearings.
Old Feb 6, 2020 | 06:12 AM
BayStYat's Avatar
BayStYat
great info, thanks Freight
fordnut66
Ford Truck Parts for Sale
Dec 1, 2009 08:56 PM
jhrsmail
Sep 4, 2007 04:44 PM
eco
Oct 21, 2006 02:05 PM
bigblack89
26
Feb 29, 2004 01:16 AM
