Intermittent no start
Old Jan 31, 2020 | 09:39 AM
Cole Slatcher's Avatar
Cole Slatcher
Hi guys my 1993 f250 with 168k miles on a 351 Windsor has just developed an issue that it doesn’t start for a good try or two. Cranks perfectly fine and strong, but no start. Few tries later it starts and runs perfectly fine. It might have something to do with it being cold in the morning but it hasn’t been happening long enough to determine that, any thoughts on what might be going bad, things to start replacing? Thanks.
Old Jan 31, 2020 | 11:40 AM
irhunter's Avatar
irhunter
Is that motor fuel injected?
Have you tried starter fluid when it doesn't start? That helps you figure out if the problem is spark or fuel.
Roy
Old Jan 31, 2020 | 12:14 PM
Cole Slatcher
It is fuel injected yes, I haven’t gotten to try starter fluid yet but that is a good next step I guess, it’s hard to predict when it will happen.
Old Jan 31, 2020 | 12:24 PM
irhunter's Avatar
irhunter
I understand waiting for it to happen, and, then trying starter fluid...drags out the diagnosis process. But, I can tell you from experience...replacing parts to deal with an intermittent un-diagnosed problem is not such a good idea.
You check for OBD codes?
Roy
Old Jan 31, 2020 | 12:39 PM
Cole Slatcher
I didn’t check it I actually don’t really know how, it’s obvious got the OBD1 not 2 cause it’s pre 96
Old Jan 31, 2020 | 12:48 PM
irhunter's Avatar
irhunter
May be a good time to buy a shop manual. I doubt that checking for codes will be the answer...but, it won't hurt.
Old Jan 31, 2020 | 05:15 PM
torq'ta 5 8's Avatar
torq'ta 5 8
check your fuel pressure with gauge
Part 1 -How to Troubleshoot a No Start (Ford 4.9L, 5.0L, 5.8L).
Old Jan 31, 2020 | 05:36 PM
kenny nunez's Avatar
kenny nunez
Hard start
If your engine has the crank sensor in the timing cover try un plugging the wire going to it and clean the terminals then try to tighten the spade connection. I had a CV that acted that way and that was the cause, it was covered with oil and dirt.
Can you hear the fuel pump cycle for the 2 seconds when you turn on the ignition? Get a test light and probe one of the injector connections to see if they are getting a signal on the negative side when cranking and also check if there is a spark coming out of the coil while cranking.
Hope this helps
Old Feb 1, 2020 | 09:28 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Any idea if the TFI and PIP (inside distributor) are still the originals? If yes, it wouldn't be a terrible idea to replace them and know that you have fresh new ignition parts - the two parts that most commonly fail and could leave you stranded when they do.
Vinford
Oct 19, 2019 12:43 PM
chief915
Jun 10, 2012 09:56 AM
JumpinJoe
Apr 17, 2009 06:22 PM
mike_23us
General Automotive Discussion
May 5, 2004 08:22 PM
